Thread: Bad running Gran prix
Results 1 to 11 of 11
  1. #1 Bad running Gran prix
    Sep 2016
    IN
    I have 2002 Grand Prix 3.8, I can slowly accelerate it up through the RPM's if I mash the pedal I get nothing. What would be causing this? I am getting no codes from computer.
  2. #2 Re: Bad running Gran prix
    GTP Level Member
    Jun 2016
    Cleveland ohio
    supercharged or not? how many miles? It could be several things; clogged cat, vacuum leak, dirty maf, misfires, among others.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  3. #3 Re: Bad running Gran prix
    Everything he said.
    I suspect a clogged cat. You could use a temp gun to check how hot it's getting if it has limited exhaust flow through it. If the temp at the front of the cat is way higher than at the rear, it's likely clogged up and not flowing well.
  4. #4 Re: Bad running Gran prix
    Sep 2016
    IN
    Not supercharged the cat is already off it and it has 145000
  5. #5 Re: Bad running Gran prix
    Then what else have you tried, you're not making this easy here.
  6. #6 Re: Bad running Gran prix
    Sep 2016
    IN
    That's kinda the point of the post. I just got car and am looking easiest and cheapest place to start
  7. #7 Re: Bad running Gran prix
    SWPA
    Quote Originally Posted by sparks View Post
    This is not how a forum works. We can't help you unless you help yourself. You basically have said, my car runs bad, how do I fix it?
  8. #8 Re: Bad running Gran prix
    do a tune up.
  9. #9 Re: Bad running Gran prix
    I and the most of the others here are willing to help, we just needed more information about what's going on.
    That's why we had asked which engine, what have you done and those kinds of things. Saying you just bought the car and know nothing about didn't help us any right away.
    We figured you atleast tried something to fix it but this is not the case. So doing what scotty said is the best place to start, do a tune up with the normal things like spark plugs and wires, clean the coil terminals, check vacuum hoses, clean the throttle body and MAF sensor. All general maintance stuff to start rulling possible problems out.
  10. #10 Re: Bad running Gran prix
    Aug 2016
    CT/RI Border
    Dirty MAF, bad ICM, destroyed plugs, bad fuel filter/pump, Cam sensor, there is more.
    Throwing parts at a problem is the absolute worst way to try to fix it. Do a full tuneup: plugs, wires, fuel/air filter.
    Does it still have factory intake gaskets? They are known to go bad and it can seriously hurt WOT performance.
    Sent from my ASUS_Z00TD using Tapatalk
  11. #11 Re: Bad running Gran prix
    Sep 2015
    Lansing, Michigan
    tune up/ fuel filter. any luck op?
  1. 98 gran prix
    By Fishng1 in forum Introductions/Noob Questions
    Last Post: 08-24-2013, 11:24 PM
  2. 04 Gran Prix Gt
    By slopez in forum Members Rides
    Last Post: 04-17-2013, 05:21 PM
  3. Just got my Gran Prix 2 days ago, so its without saying, I'm new here
    By deadwoodspecial in forum Introductions/Noob Questions
    Last Post: 02-27-2012, 07:27 AM
  4. New 01 Gran Prix gt
    By prixgt01 in forum Introductions/Noob Questions
    Last Post: 05-03-2010, 11:09 AM
  5. 92 Gran Prix Tranny
    By dvorak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2008, 12:31 AM
