Thread: Fuel Gauge Reading Inaccurately
Results 1 to 5 of 5
  1. #1 Fuel Gauge Reading Inaccurately
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, on my '04 GT2 the fuel gauge doesn't read correctly. Initially it would read full and empty, then it progressively showed empty (DIC warning along with the gauge reading on E) with more and more fuel in the tank (10>8>6gal needed to fill it on "empty") - and now it also sporadically shows 3/4 a tank on start-up and stays that way until shut off. I'd assume, and given the reading I've done, that I simply need to replace the fuel pump level sensor. But, the one Dorman one I read is really cheap and you have to re-use some of the original stuff. Is there a better brand, or is the Dorman the best I'm going to find and they're all cheap?
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: Fuel Gauge Reading Inaccurately
    GT Level Member Hpiracr28's Avatar
    Apr 2016
    Elmira, NY
    I literally just dealt with this with the help of the fellas on here. My grand prix is an 03 3.1 v6 tho. Mine was pegged between 3/4 and full. Replaced sensor, and still didn't show correct fuel level. There is a write up by onlywinged1 if you Google the gas gauge not working, but it's a lot of wire chasing, voltage/resistance testing, and time. I said screw it and will just refill every 400 miles since I'm assuming it wasn't just the fuel level sensor. Your issue might just be that. But I was told to not by the $90 acdelco sensor, but either the Dorman or tech smart brand.
  3. #3 Re: Fuel Gauge Reading Inaccurately
    Jun 2015
    Okay, I'll try the Dorman - hopefully it fixes it.... I did see your thread actually, wasn't sure if the 6th Gen with a 3.1 was going to be the same as my 7th gen with a 3.8. And, actually, lately it's been jumping around between 1/2, 3/4, and full, so - it has a mind of its own.
    I plan on selling the car, so, was trying to get rid of all the quirks beforehand, lol.
  4. #4 Re: Fuel Gauge Reading Inaccurately
    Apr 2016
    Elmira, NY
    Yeah, I could move the float arm by hand and it would register from empty to full on the gas gauge, but once it was in the tank, no go. Not sure why it would work out of the tank and not in it but I spent too much time on it, got frustrated and said screw it. Maybe I'll get lucky and fill it up and it'll read right lol. Doubt it but whatever.
  5. #5 Re: Fuel Gauge Reading Inaccurately
    Aug 2016
    Norfolk, VA
    There's a thread over on Duramax forum about this (or related issue). The rheostat in the sender makes intermittent contact which affects your readings for the fuel level. In the trucks they tend to show empty, but occasionally bounce to the appropriate level before dropping off again. A lot of guys buy the cheaper GM sender and pop rivet the rheostat into the original unit since the diesel-specific sender is outrageously expensive.
  1. Fuel gauge reading incorrectly
    By 310toumad in forum General Tech Discussion
    Last Post: 11-30-2015, 11:55 PM
  2. Fuel gauge reading wrong
    By Jason97GrandprixGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-29-2015, 07:52 PM
  3. Problem with EGT gauge reading
    By camopaint0707 in forum General Tech Discussion
    Last Post: 07-31-2013, 04:23 PM
  4. Gas Gauge Not reading right-goes to empty
    By fixit10101 in forum General Tech Discussion
    Last Post: 08-07-2011, 12:33 AM
  5. Temp Gauge Not Reading RIght
    By 2000 Grand Prix GT Blue in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2010, 12:08 PM
