Thread: What's the pressure I should see in my AC
Results 1 to 10 of 10
  1. #1 What's the pressure I should see in my AC
    SE Level Member 01grandpri's Avatar
    Oct 2015
    allendale michigan
    2002 gtp . What pressure should I see whe. I put my gauges on the compressor. When running that is..anyone know?
  2. #2 Re: What's the pressure I should see in my AC
    GXP Level Member
    Mar 2015
    Tomball
    45 on the low side and 240 on the high side at about 80°
  3. #3 Re: What's the pressure I should see in my AC
    Dec 2012
    Where 4T65E's were born
    25-45 is the normal low side pressures, which is what you will mainly use for filling per pressure. 25 would be on a cool dry day, and 45 would likely be a very hot and humid day. You can find charts for temperature/pressure.
    Sold.
  4. #4 Re: What's the pressure I should see in my AC
    Oct 2015
    allendale michigan
    I looked on google and I couldn't find it.. I live in Michigan during the summer it's very humid..
  5. #5 Re: What's the pressure I should see in my AC
    Buffalo
    Look up a pt chart dude
  6. #6 Re: What's the pressure I should see in my AC
    GT Level Member mguzzo's Avatar
    Buffalo NY
    crazy guy do you have A/C equipment? vac pump, etc?
    I installed a new condenser but need to do a leak down test.
    Maybe ill load in some dye and pressurize it, the dye will look like a murder scene under black light if there's a leak,
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  7. #7 Re: What's the pressure I should see in my AC
    Buffalo
    Quote Originally Posted by mguzzo View Post
    yessir I do
  8. #8 Re: What's the pressure I should see in my AC
    Oct 2015
    allendale michigan
    Yes I work on AC diesel reefers for a living
  9. #9 Re: What's the pressure I should see in my AC
    Buffalo NY
    Me thinks a mod day at one of our houses is in order soon then.
  10. #10 Re: What's the pressure I should see in my AC
    Buffalo
    I'll be having some time off soon. If you need to use some tools , no worries.
  1. Hi pressure low pressure fuel connectors , i lost the springs that go inside. help
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2014, 09:31 PM
  2. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  3. oil pressure kit
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 06-27-2010, 09:12 PM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
