Thread: Help!!!!! 07 gxp is dead
Results 1 to 20 of 37
  1. #1 Re: Help!!!!! 07 gxp is dead
    Apr 2016
    Maryland
    Quote Originally Posted by rottonj View Post
    How old is the battery? It may show correct volts but not pass a load test. The sensor Scottydoggs is on the negative terminal, and a pain to replace.
    What is that sensor called
    Sent from my XT1060 using Tapatalk
  2. #2 Re: Help!!!!! 07 gxp is dead
    Dec 2013
    Enfield
    Quote Originally Posted by Dacton1985 View Post
    Battery current sensor. it is a replaceable part as the 08 models got updated ones I believe. Requires cutting cable to get it one there . or replacing the entire cable. Should be able to be tested . its a sensor.
    This is for an 08, may be different for yours. One is for 5V, and one is for 10v. May not be your problem, just a thought.
    ACDELCO 13505369
    ACDELCO 10306471
    Just google the problem, something will come up as to what to look for. Good luck
  1. ECM dead or not dead
    By Egibb12 in forum General Tech Discussion
    Last Post: 08-11-2012, 10:57 AM
  2. 97 GTP DIC dead... Help please
    By Prixer97 in forum Audio, Security & Visual Electronics
    Last Post: 06-29-2012, 02:28 AM
  3. GTP is dead
    By JayGTP02 in forum The Rant Forum
    Last Post: 05-15-2009, 12:07 AM
  4. Hello I am the Dead-Man
    By iamthedeadman in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:31 PM
  5. car = dead
    Last Post: 02-10-2009, 09:03 PM
