Thread: Axle Nut Size?
Results 1 to 14 of 14
  1. #1 Axle Nut Size?
    Massachusetts
    Does anyone know what the size of the axle nuts are on the front wheels? Getting ready to replace my wheel hub assemblies and want ot make sure I have the correct size socket before I get started. Thanks!
  2. #2 Re: Axle Nut Size?
    SWPA
    Beleive its actually 34mm, but most people including myself, have gotten away with using 36mm.
  3. #3 Re: Axle Nut Size?
    This
    04 Comp G.
  4. #4 Re: Axle Nut Size?
    GTP Level Member
    Oct 2014
    ^^^ some are 35 and you can get by with a 36. Trying it on a 34 may be pushing it.
    Sent from my iPad using Tapatalk
  5. #5 Re: Axle Nut Size?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I use a 36 MM on mine. It's loose but it works.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  6. #6 Re: Axle Nut Size?
    May 2008
    Schuyler, NE
    I've seen anywhere from a 32-36, depending on which axle you have.
  7. #7 Re: Axle Nut Size?
    Massachusetts
    The axles are the original ones that came on the car. I've owned it since it was new.
  8. #8 Re: Axle Nut Size?
    Massachusetts
    It's a 2000 GT if that helps sort out the size. I've looked in the factory service manual but is does not address fastener sizes.
  9. #9 Re: Axle Nut Size?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    When I replaced my cv axles, the old one was a 35 mm but the new axles were 34mm.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  10. #10 Re: Axle Nut Size?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    The axle nuts on my 98 GT, 01 GT and 02 GTP are all 34mm. FYI, if you go to Advance Auto, they have an axle socket set as a loaner tool that you can use for free. They basically charge you the $65 cost of the set then refund it when you bring it back. You can own a set for $35 (after 20% coupon ) from Harbor Freight, that's the set I have. They come in handy.
    You should also have a 1/2" drive torque wrench, the spec on the axle nut is 118 ft lbs, overtightening the axle nut will cause premature bearing wear and failure. On sale for $22 at Harbor Freight.
    Public Service Message: axle nuts are one-time-use, they use a special stretch-to-fit locking process. You should use new axle nuts if you remove them, but almost nobody does....
  11. #11 Re: Axle Nut Size?
    Dec 2013
    Enfield
    Did a set of fronts not too long ago on a 2004, 34 was too big and was sloppy on the nut. This is what I used.
    http://www.amazon.com/TEKTON-4943-2-...ilpage_o05_s01
  12. #12 Re: Axle Nut Size?
    SE Level Member james782004's Avatar
    Nov 2015
    34mm
    Sent from my SM-G920R4 using Tapatalk
  13. #13 Re: Axle Nut Size?
    Jul 2010
    Coquitlam,BC,Canada
    36mm on my '02 GT.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Axle Nut Size?
    Massachusetts
    Thanks to all for responding. Now to get a socket and get to work!
  1. Torque rating for wheel bearings ? Axle nut size ?
    By GTP in RTP in forum Brakes/Suspension/Chassis
    Last Post: 02-12-2016, 04:45 PM
  2. What size socket for rear axle nut (bearing replacement)
    By poopoopeepee in forum Brakes/Suspension/Chassis
    Last Post: 07-05-2013, 04:01 PM
  3. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  4. Axle Nut Size?
    By 2000GTP in forum General Tech Discussion
    Last Post: 10-27-2009, 08:39 PM
  5. Grr. Axle Nut Size?
    By Gregorius in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2009, 06:35 PM
