Thread: 04 GT....The Sunroof....solved
Results 1 to 19 of 19
  1. #1 Re: Second of two problems....The Sunroof....
    Jan 2014
    AR
    Thats probably going to be a messed up sunroof regulator. Plastic screw-type drive thingy can strip out or eat debris then once a chunk is gone its toast. If its a 6th gen with a pop-up / slide back sunroof, I know you can drop the overhead console where the switch is, and take the motor loose. Might need a visor loose and the tricky sunroof trim ring off to get access. But if you take the motor loose from the reg, you can cycle it by hand then you'll see. Any grindy noises or notchy operation mean quit messing with it until you can replace the huge regulator. You don't want to have it stuck open lol.
  2. #2 Re: Second of two problems....The Sunroof....
    SE Level Member Bad67bird's Avatar
    Apr 2016
    DFW
    Quote Originally Posted by idrivejunk View Post
    thanx for the info,im going to try and mess with it this weekend,gotta make the MRS happy you know.......i like your "junk" 69 gp....455 stocker or stock appearance with attitude inside?
    1967 Firebird 400 , 2004 Grand Prix GT, 2000 Bonneville SE
  3. #3 Re: Second of two problems....The Sunroof....
    Jan 2014
    AR
    Quote Originally Posted by Bad67bird View Post
    Well... Its a '71-2, bored .030, has plain low compression small valve heads. But with HEI, Eddy intake & 750, unknown # Schneider cam (approx RA4?), Doug's 3 tube headers, TorkMaster 2000 B&M converter, TCI Trans-Scat stage 1 shift kit (manual but not full manual), HD sprag, deep pan and brass filter, lets see... unknown el Camino 12-bolt with 3.31s I think. With the old 400, I had potential for 14 flat, best was a 14.2 @ 95. That was overcammed but this 455 is a better recipie and is just strong overall. Runs out of air past 4.500. I have some big valve heads and Harland Sharps I need to swap on. So really, not much more attitude than a GTP but it sounds and withstands punishment way better. The FWD GPs are the "junk" but the old one is sliding downhill too.
  4. #4 Re: Second of two problems....The Sunroof....
    Apr 2016
    DFW
    Ok picked up. Complete sunroof assembly and steering column for 140...... Gonna try to get everything working tomorrow!
    i will post up details on how it turns out.
  1. HUD problems
    By Jakescoots in forum Audio, Security & Visual Electronics
    Last Post: 07-29-2013, 09:16 PM
  2. Abs problems
    By sammie in forum General Tech Discussion
    Last Post: 09-11-2012, 05:33 PM
  3. HUD problems..........
    By cmoney23 in forum General Tech Discussion
    Last Post: 09-05-2012, 10:17 AM
  4. 2 problems HELP!!!
    By Frank4202 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2011, 07:04 PM
  5. Problems with a 97' GT
    By drumstom in forum General Tech Discussion
    Last Post: 12-11-2009, 11:00 PM
