Thread: Trans question
Results 1 to 10 of 10
  1. #1 Trans question
    SE Level Member d68barnes's Avatar
    Apr 2016
    I looking to turn more rpm s at 55 mph on my gtp were is beat place to get different gears for chain in trans with out sending alot
    Sent from my HTC Desire 626s using Tapatalk
  2. #2 Transmission
    Apr 2016
    Where to get different gears 35/35? With out spending a lot I won't to turn more toms at 55 mph
  3. #3 Re: Transmission
    Mar 2014
    Tucson
    I think the u-body (minivan) had 35/35 gears.
  4. #4 Re: Transmission
    Apr 2016
    Thanks
  5. #5 Re: Trans question
    GT Level Member WickedGoat's Avatar
    Dec 2014
    Missouri
    Without spending a lot? Don't know... But forum sponsor TEP who knows these transmissions better than anyone should be the first place to look for info and pricing. If you are doing the work yourself, then you can probably buy parts from TEP or source them yourself.
    2014 Chevy Impala LTZ Limited -- Silver/Black, Grand Prix replacement
    2004 Pontiac GTO -- my garage queen
    2004 GMC Yukon SLT -- wife's daily driver
  6. #6 Re: Trans question
    take it out of overdrive, why you want higher rpm's? thats just a waste of gas.
    gears, labor to install and the tune for them will not be cheap.
  7. #7 Re: Trans question
    Nov 2011
    NY
    ^^^this^^^
    and also...
    Cheap/Fast/Reliable
    you can have only two at any time, chose wisely... Example - cheap/fast is not reliable, cheap/reliable isn't fast... Get the picture!
    question: what is your intent to have more rpm's @ 55mph?
    You left out a lot of info., like what engine, what mod's, etc.,
  8. #8 Re: Trans question
    Apr 2016
    Thanks I found set of 35/35 gears on eBay
  9. #9 Re: Trans question
    Apr 2016
    At 55 mph car only turned 1500 rpm with headers and cat delete it quite r turning more rpm it would be more responsive and torque converter would stay locked in more
  10. #10 Re: Trans question
    hangover park IL
    55/60 mph and below I drive around in manual 3rd (D not OD) and I have 2.93 fdr like the gtp's
    4th is a fuel econ/cruise gear, use it as such.
    if you have a TCC shuttling issue, your best bet is to change the tcc apply/release tables so that its to your satisfaction
    ~James~ Psychotic Gearhead
  1. Trans question
    By GoTmEa05L67 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-25-2014, 11:37 PM
  2. Trans question!
    By CyxRyan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-09-2013, 08:14 PM
  3. 00' GP trans question
    By xNUMNUTSx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2010, 12:38 PM
  4. Trans question
    By davidl25 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2009, 07:27 PM
  5. Trans question
    By CompCam21 in forum Introductions/Noob Questions
    Last Post: 06-14-2009, 11:38 PM
