Thread: Regarding code P0332.....
Results 1 to 3 of 3
  1. #1 Regarding code P0332.....
    Apr 2016
    KY
    My car has been coding this for the past couple months. I've had no problems with the engine running rough or anything, but I guess I need to think about changing out the knock sensor eventually.
    And lucky me, of course it's the one in back. Just wondering if anyone has dealt with replacing one of these rear position knock sensors, and if so what was involved, how much of a pita it was, etc. Thanks folks!
  2. #2 Re: Regarding code P0332.....
    GXP Level Member
    Mar 2015
    Tomball
    Yes I have. You will have to remove the sensor and then move it to the passenger side. Remove the pass side wheel and then push the sensor up over the transmission then using a telescoping magnet to reach in the wheel well and lift it out. To get the new one in I used a gun cleaning rod to put it back into the hole and get it started. Trying to use a socket and an extension keeps it tilted just enough so it doesn't want to go back in. When you get it about a thread in you can slide the socket and extension back in there and tighten it to 14 ft/lbs.
    you're going to get wet when you remove that sensor, btw.
    Jeff
  3. #3 Re: Regarding code P0332.....
    Apr 2016
    KY
    Jeez, sounds like quite an endeavor! Thanks for the help.
  1. P0332 Knock Sensor 2 Circuit Low Input (Bank 2) code HELP
    By Yarbeau in forum General Tech Discussion
    Last Post: 12-20-2014, 06:07 PM
  2. Code P0332 and a misfire, help.
    By Metal Links in forum General Tech Discussion
    Last Post: 06-07-2014, 09:23 PM
  3. code p0171 p0332 wont start now
    By juanathandavid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 05:29 PM
  4. P0332 code
    By IllegalIntentions in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2010, 01:45 AM
  5. Need Help with p0327 and p0332
    By midblue00 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 08:22 AM
