Thread: 2007 Grand Prix, 3.8L, SC - No Cabin Heat/Contaminated Coolant/Overheating
Results 1 to 4 of 4
  1. #1 2007 Grand Prix, 3.8L, SC - No Cabin Heat/Contaminated Coolant/Overheating
    Apr 2016
    Columbia, MO
    If anyone out there can help me, I'd sure appreciate it. I have multiple symptoms, but can't tie them together (if they need to be).
    Low Cabin Heat
    Outside Air Temp. = 51°F
    Discharge Air Temp. = 102°F
    Coil Inlet Hose = 160°F
    Coil Outlet Hose = 135°F
    Coil backflushed with no improvement
    Coolant
    Coolant just flushed but looked and smelled bad prior to flush
    Contaminants (oil?) still present in new fluid (darker but not as bad as before flush)
    System vented of air
    Oil
    Oil clean but just changed less than a week ago
    Car has used oil for over two years not, but no external leaks nor smoking
    Periodically Overheats
    Thermostat replaced 6 weeks ago
    Other
    Transmission Fluid clean
    Power Steering Fluid clean
    No external leaks
    No smoke at all
    No loss of power
    Car runs smoothly
  2. #2 Re: 2007 Grand Prix, 3.8L, SC - No Cabin Heat/Contaminated Coolant/Overheating
    Is that with the car fully warmed up??
    One heater core hose should be at or very near the coolant temp of the motor when warm, so roughly 190-195º. You might still have sludge build up in the core.
    If you replaced the dexcool coolant, good luck getting all the stuff out on just one flush. It might take 3-5 flushes to get all that junk of the system. Dexcool and air do not like each other, thus the oil film or sludge you can see.
    Burning oil is just something some 3800's do, the bonneville we have and the grand prix (both 2002's) burn oil. I've changed the PCV on each and they still do the same thing, even replaced the intake manifold on one for prior issues but it didn't help anything.
    1 quart per 3,000 miles is normal per GM, you won't notice smoke with that. And all cars do burn oil, impossible not too but just some more than others.
  3. #3 Re: 2007 Grand Prix, 3.8L, SC - No Cabin Heat/Contaminated Coolant/Overheating
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    It does take a long time to get the nasty dexcool out.
    I got a impala. It has the 3400 engine. The owner told me after I bought it what oil he was using. It was like 40w15 diesel oil. I was like what the hell? I normally run 5w30 in my cars. I threw 10w30 in it to compensate for the oil he was using.
    I drove 100 miles, and it was black. Changed again. Drove 250 miles, put seafoam into crankcase and it was black as black again. I have about 50 miles on this last change, been working on the suspension.
    Also, i should say most gms will use oil after awhile. My 08 g6 with 103K miles uses about 1/2 to 1 qt of oil every 3000-4000 miles. It matters how long it was since I changed it. I compensate with putting 5qts instead of the recremended 4.5qts.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  4. #4 Re: 2007 Grand Prix, 3.8L, SC - No Cabin Heat/Contaminated Coolant/Overheating
    Dec 2013
    Enfield
    Could be air in the cooling system still or a partially plugged heater core. Be sure fans are operating if overheating.
  1. 05 Grand prix GT coolant/overheating problems
    By sasquatch094 in forum General Tech Discussion
    Last Post: 09-08-2013, 08:02 PM
  2. 05 Grand Prix GTP...car overheating/ not heat from heaters
    By Rileys05GTP in forum General Tech Discussion
    Last Post: 02-19-2012, 02:08 AM
  3. Coolant Smell-Grand Prix GT 2007
    By Allison in forum Introductions/Noob Questions
    Last Post: 10-29-2010, 07:23 AM
  4. Coolant temps 2007 Grand Prix SC - Normal?
    By ViPER1313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2010, 02:06 AM
  5. 2007 Grand Prix GT - 6 cyl - Cabin Air Filter
    By lvbenella in forum General Tech Discussion
    Last Post: 06-25-2010, 01:47 PM
