Thread: Air bag light staying on
Results 1 to 4 of 4
  1. #1 Air bag light staying on
    Mar 2013
    Canada
    I had to change the multifunction switch in my Grand Prix 2008, before I did that I removed the air bag fuse which is fuse 9. After I was all done everything was working fine, until my gmos after market harness for my radio burnt out causing my car battery to drain. Battery Is fully charged but now the air bag light is on I checked the fuse it is still intact. Now I am not sure if the airbag light was on after I installed the new multifunction switch. Any feedback is much appreciated in how can I troubleshoot the airbag light.
    Sent from my SGH-I337M using Tapatalk
  2. #2 Re: Air bag light staying on
    St. Louis
    Have it scanned for codes and see what it says. Not sure if Autozone scanners can pick up SRS codes or not. Beyond that, if the aftermarket harness burnt up somewhere in the steering wheel maybe it took out a wire for the airbag?
  3. #3 Re: Air bag light staying on
    GXP Level Member
    Mar 2015
    Tomball
    Interesting.
  4. #4 Re: Air bag light staying on
    Mar 2013
    Canada
    Well decided to take it to my local garage as they have the scanner. Error code was saying it was the passenger side. We went back inside on his computer and had a look at the wiring digram because it is strange that the key fobs weren't working as well. Turned out to be a fuse missing, the fuse was the RFA / MOD used for the Key FOBs. I assumed they piggyback the power on that. How the hell did that fuse pop out? I sure didn't remove it.
  1. Seat belt light staying on
    By bluebsh in forum General Grand Prix Discussion
    Last Post: 08-20-2015, 06:07 PM
  2. ABS Light staying on
    By 98IndyGP in forum General Tech Discussion
    Last Post: 07-19-2012, 10:25 AM
  3. HELP!!! DRL's Staying On
    By kodeblue in forum General Tech Discussion
    Last Post: 01-21-2012, 02:53 AM
  4. wipers staying up
    By Jakegday in forum General Tech Discussion
    Last Post: 12-15-2009, 03:35 PM
  5. abs and trac off light staying on
    By gtpinsc in forum General Tech Discussion
    Last Post: 08-20-2008, 07:34 AM
