I need tap into the accessory power as I need to power my dash cam and a USB charging port. Anybody know what pin or color wire is the accessory wire going to the OEM radio harness in a GP 2008 base model? Had a look at the wiring and normal it's red but no red wire. Either that or I connect it to the fuse box by using an add-a-fuse but if I go down this route I need know what fuse I can use that has power only when the key is in the ignition. Thanks
Sent from my SGH-I337M using Tapatalk
