Thread: Engine and trans mounts replaced. Other issues?
Results 1 to 16 of 16
  1. #1 Engine and trans mounts replaced. Other issues?
    Aug 2015
    Austin, TX
    05 GP GT, 105k miles. In December I replaced trans mount and lower left engine mount. Both had deteriorated rubber, but no oil contamination. No oil leaks. This week I had to replace the upper right torque mount bracket, as it had failed at the weak points, in front of each of the back bolts into the cylinder head. I replaced the stock aluminum bracket with a Dorman cast iron one, which is a lot heavier/sturdier. Wondering if there could be another issue why almost all the mounts would fail in a short amount of time, or is it just time/miles, and if I should be looking for further issues contributing to mounts blowing out. I've owned this vehicle for 15 months, prior owner was the only other owner. By all accounts they had taken care of the vehicle very well, as have I, and it runs and drives practically like new. I have a 98 firebird that I've owned for 18 years and its still on the original mounts, so that's one reason I'm questioning it. Have never had a mount issue with any other vehicle I've owned til this one.
    Thanks for your help!
  2. #2 Re: Engine and trans mounts replaced. Other issues?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    It might just be a domino effect... one mount goes out, and it puts additional stress on the remaining mounts, causing them to fail faster.
    And the factory aluminum engine mount is junk... snapped one on my Impala, replaced with a junkyard one, broke that too. Replaced with a junkyard L67 (cast iron) mount bracket, no more issues.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  3. #3 Re: Engine and trans mounts replaced. Other issues?
    Aug 2015
    Austin, TX
    That's kinda what I'm assuming. Well, only 2 other mounts can go on it! The upper right bracket was a ***** because of that one bolt that angles towards the upper IM and has practically no clearance to get a wrench on it with the injector right next to it and angled over the top of the bolt head. The others appear rather simple to replace... so there's that...
  4. #4 Re: Engine and trans mounts replaced. Other issues?
    Oct 2016
    NH
    Quote Originally Posted by Impala131 View Post
    I just picked up a cast iron mount / coil bracket to replace the broken passenger side bracket on my 2000 Impala. Any tricks to this swap? Or does it bolt right in? Thanks!
    Sent from my MotoG3 using Tapatalk
  5. #5 Re: Engine and trans mounts replaced. Other issues?
    Aug 2015
    Austin, TX
    Quote Originally Posted by kuhnzoo View Post
    Did you get the bracket for the supercharged 3800 or the N/A 3800? The one that installs on the supercharged is fairly simple as it bolts up under the coil pack module. The one that bolts over the valve cover onto the manifold is kind of a *****. That is the one I replaced, and even though I have no issues with valve cover gasket I wish I had done the gasket too because I will not look forward to removing/reinstalling that mount again.
  6. #6 Re: Engine and trans mounts replaced. Other issues?
    Oct 2016
    NH
    I think it's from a sc 3800 since it bolts to the end of the head. However, when I took THE ICM and coils off the OEM aluminum ICM mount, it does not bolt right onto the cast iron mount.
    My coils and ICM are held on the OEM mount with 6 little bolts on the coils.
    Any ideas?
  7. #7 Re: Engine and trans mounts replaced. Other issues?
    Oct 2016
    NH
    Here is the cast iron mount. It is the combination motor mount and coil pack bracket.IMG_20161106_173534294.jpg
  8. #8 Re: Engine and trans mounts replaced. Other issues?
    Oct 2016
    NH
    The bracket bolts on the end of the head.
    View of the col pack mount area. My ICM and coils will not mount to the three holes shown.
  9. #9 Re: Engine and trans mounts replaced. Other issues?
    re drill the coil mount. i had to re drill all 3 holes when i modded mine and moved the icm over a 1/2 inch or so.
  10. #10 Re: Engine and trans mounts replaced. Other issues?
    Oct 2016
    NH
    Problem is that my ICM does not bolt to the mount in the OEM configuration. It is sandwiched between the 3 coil packs and the OEM coil pack mount. Each coil pack is fastened with two small diameter bolts that go through the ICM and thread into the OEM mount.
  11. #11 Re: Engine and trans mounts replaced. Other issues?
    so your icm plate dont look like this is what your saying? if so you'll need to grab one up i guess.
  12. #12 Re: Engine and trans mounts replaced. Other issues?
    Oct 2016
    NH
    Yep. I just found that setup doing a Google search. Apparently, I need this adaptor baseplate and the bolts.
  13. #13 Re: Engine and trans mounts replaced. Other issues?
    its just a supercharged icm plate. i guess they are not all the same. you'll want to grab the three nuts and bolts too when you snag another one. and maybe the coil bolts.
  14. #14 Re: Engine and trans mounts replaced. Other issues?
    Oct 2016
    NH
    The NA 3.8 in my 2000 Impala does not have this baseplate. The oem aluminum mount on the end of the head acts as the baseplate and the coils bolt to it (sandwiching the ICM).
    Now I need to find this baseplate and bolts. Or make one from some aluminum plate.
    Thanks for the info. Have a spare baseplate and bolts by chance?
  15. #15 Re: Engine and trans mounts replaced. Other issues?
    i dont, i sold it, and then the guy cracked it from over tightening it..... cant win all the time.
  16. #16 Re: Engine and trans mounts replaced. Other issues?
    Oct 2016
    NH
    Bummer! But glad to have the info I need to make this work.
    Thank you!
  1. Engine/Trans mounts?
    By Cordless in forum 5.3L V8 (LS4)
    Last Post: 05-27-2016, 10:38 AM
  2. shorter dog bones with poly engine/trans mounts
    By TEK310 in forum General Tech Discussion
    Last Post: 12-09-2013, 04:53 PM
  3. Replacing Engine and Trans Mounts. Part Numbers?
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-14-2011, 08:08 PM
  4. Autozone SOLID engine and trans mounts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 08-17-2009, 08:19 PM
  5. Strut Mounts and Bellows replaced.
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 06-02-2009, 12:55 AM
