Thread: Replacing Engine - Should go with NA like what I had or go SuperCharged
Results 1 to 5 of 5
  1. #1 Replacing Engine - Should go with NA like what I had or go SuperCharged
    GT Level Member mainecrab's Avatar
    Feb 2008
    Hey guys,
    I had my car lose oil and sounds like rod bearing or other on the crank or piston is knocking. I got a new car but really thinking about fixing this one up since it is basically in fairly decent shape and doubt I would get more than $500 or so from it if I sold it, and if someone even wanted to buy it in the first place.
    It is a 97 Grand Prix GT of course NA 3.8. If I were to get a supercharged engine would I need to get the transmission that goes with that too or would the one already there work too? Also if you get an engine can you use your PCM? I assume with a supercharged one I need a supercharged PCM to go with that.
    I am really going back and forth about selling it for what I can get or just making it a project car especially since it isnt far off from being a classic in 6 years.
  2. #2 Re: Replacing Engine - Should go with NA like what I had or go SuperCharged
    you need the pcm tuned same tranny works.
  3. #3 Re: Replacing Engine - Should go with NA like what I had or go SuperCharged
    The 97's have a 4T60e, not a regular 4T65e.
    I would get a different transmission. The vac assisted 4T60 is not a great choice.
  4. #4 Re: Replacing Engine - Should go with NA like what I had or go SuperCharged
    Kemmerer, Wyoming
    Dave at TEP said he could rebuild a 4T60 to take 4T65 internals, but it would probably cost less to go with a junkyard 4t65
  5. #5 Re: Replacing Engine - Should go with NA like what I had or go SuperCharged
    Feb 2008
    Thanks for the input. So looks like I should go with an upgraded transmission with the supercharged engine if I go that route but it could work with what I have so far.
  1. How to tell if an engine is supercharged
    By CodeRedHoover in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2013, 05:42 AM
  2. Question about replacing supercharged drive belt.
    By Kilroy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2013, 08:47 AM
  3. Replacing Engine, need help deciding on engine
    By Curt7 in forum General Tech Discussion
    Last Post: 08-06-2011, 11:24 PM
  4. replacing engine - need help
    By BenZ in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-06-2010, 08:16 AM
  5. 3.8l supercharged engine
    By fritzie001 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2010, 12:46 PM
