Thread: Swaping engine and trans from top ( first timer)
Results 1 to 20 of 645
  1. #1 Re: Swaping engine and trans from top ( first timer)
    try using your icm and coils.
    also make sure the icm harness ground wire is bolted on. if you took the front valve cover off you took the coil bracket off, that black wire gets bolted to the brackets bolt.
  2. #2 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    i have no clue how to use icm or coils? I made sure the fround was onbefore installing the icm
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
