Thread: Will these fit?
Results 1 to 10 of 10
  1. #1 Will these fit?
    SE Level Member bluesfan4life1955's Avatar
    Mar 2015
    Hey yall just wanting to get some peoples opinion on whether or not these would fit between the headllights also in the middle of the bumper and the core support thanks again. Btw i already have a 5 gallon tank and all the required hardware needed plumbed and wired in my trunk
    Will these fit? Attached Images
  2. #2 Re: Will these fit?
    whats the dimensions?
  3. #3 Re: Will these fit?
    Mar 2015
    its a 5 trumpet setup as seen the longest horn is 22 inches by 3.25 circumfurance
    № 1 19.5″, № 2 16.25″, № 3 14.75″, № 4 12.75″№ 1 495.3 mm, № 2 412.75 mm, № 3 374.65 mm, № 4 323.85 mm
    that is a better length and diameter of the horns and i know that the horn in the in the middle will fit it is small enough
  4. #4 Re: Will these fit?
    Jul 2010
    Coquitlam,BC,Canada
    Is there even 22" of clearance?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Will these fit?
    SWPA
    They wouldn't fit without some serious hacking and modification. So not worth it for a few giggles.
  6. #6 Re: Will these fit?
    Mar 2015
    even if i angle them side ways
  7. #7 Re: Will these fit?
    only way i think that fits is if you mount a bracket top to bottom on the side of the rad support, then mount it to the bracket.
  8. #8 Re: Will these fit?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I want a train horn real bad lol.
  9. #9 Re: Will these fit?
    Mar 2015
    im thinking of running two aiming to the driver side and the smaller of the 5 to the passenger side and have it all connected in the middle of the car it should still be super fu1king loud anyway i run them
  10. #10 Re: Will these fit?
    Jul 2010
    Coquitlam,BC,Canada
    That pic must be generic, cuz the big trumpet is not 22" long. I'd look for shorter trumpets for our cars, maybe 10"-15" max.
    I had a single 10" in my Bronco.....
    And FYI, a 5 gallon tank is WAY overkill for horns. 1-2 gallon is more than sufficient.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
