Thread: How hard to swap 3.1 from '99 Century to '94 GP?
Results 1 to 4 of 4
  1. #1 How hard to swap 3.1 from '99 Century to '94 GP?
    Kissimmee, FL
    I looked through all 26 pages of the tech write-ups & did not see this particular swap mentioned. I am new to Pontiac; though I have had several 4 cyl. Cavaliers over the years.
    The GP is running but has a really bad miss that was traced to very low compression on #6. I can get a low mileage 3.1 from this Century for a good price but I'm wondering if or I should say what issues I will have. I will be getting the whole car so if there's any parts I need from the Buick; it will be available.
    I'm mainly concerned if it will bolt up and the electrical issues (OBD I vs OBD II), sensors, etc.
    I would like to move on getting the Century quickly so I'm hoping that someone can confirm this swap will work. I'm having a bit of a hard time finding a good site that has this interchange information.
    Thanks for any and all posts! You can even call me names if that makes you feel better. No ego here; just want to get this done.
  2. #2 Re: How hard to swap 3.1 from '99 Century to '94 GP?
    I'd look at the motors themselves, what engine code each are.
    I think they are too different to be a direct swap. The OBD 1 isn't going to be anything like the OBD 2 motor thats for sure.
  3. #3 Re: How hard to swap 3.1 from '99 Century to '94 GP?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I swapped a motor from an 01 into my 94 CS. I didn't do most of it because I was working such long hours. Basically used the block and heads and swapped everything else from my 94 and it runs great still many years and miles later.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  4. #4 Re: How hard to swap 3.1 from '99 Century to '94 GP?
    SE Level Member 95naSTA's Avatar
    Philly
    check 60degreev6.com
    95 Bonneville SLE: L36/F40/E39. 98 Infiniti i30: VQ35HR/5MTVLSD. 07 Ducati Monster S2R 800: DS1000 swap. 74 Yamaha DT175: Brap.
  1. Replies: 4
    Last Post: 03-02-2019, 11:28 PM
  2. Working hard...or HARD at work
    Last Post: 05-03-2013, 01:19 PM
  3. How hard is it to swap a 2004 Grand Prix gt to a gtp 3.8
    By Bigcountry198922 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2013, 03:16 PM
  4. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  5. Burn of the Century
    Last Post: 02-23-2011, 05:49 PM
