Thread: swapping a supercharged motor to my 94 GTP?
Results 1 to 15 of 15
  1. #1 swapping a supercharged motor to my 94 GTP?
    Aug 2012
    gladstone OR
    Wondering about the possibility of swapping a supercharged motor to my 94 GTP? What all is involved? What's a good year candidate for the donor. Trans and all I assume. I'll bet there is a thread for this?
    Thanks
  2. #2 swapping a supercharged motor to my 94 GTP?
    Anythings possible with Jesus
    Oh and money, and skill etc
    04 Comp G.
  3. #3 Re: swapping a supercharged motor to my 94 GTP?
    Dec 2010
    DMV
    Quote Originally Posted by REDCRAPGP View Post
    Anything possible with Jesus
    Lol yup
    Sent from my LG-H900 using Tapatalk
  4. #4 Re: swapping a supercharged motor to my 94 GTP?
    Donating Users timboku's Avatar
    Montgomery, IL
    Mod Guide: How To: L67 Swap - Monte Carlo Forum - Monte Carlo Enthusiast Forums
    http://montecarloforum.com/forum/fwd...67-swap-14610/
    Follow this, I'm putting a l32 into my 95 cuttlass....you will need a new Trans so need to get a 4t65e, and you'll need the obd2 harness to convert your obd1...but parts list and I structures in the link..motor and Trans bolt right in..
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #5 Re: swapping a supercharged motor to my 94 GTP?
    Oct 2014
    St Augustine FL
    I did this with a 92 Lumina Z34 about 12 years ago. It bolts in you basically need a donar car with the engine, transmission all accessories wire harness and ECU. Lots of work but it is fun seeing peoples faces when you pop the hood.
  6. #6 Re: swapping a supercharged motor to my 94 GTP?
    hangover park IL
    Just an f.y.i for parts sourcing you will be looking up a lot of stuff for 95 and 96 Regals with the 3800 series 2. that will give you things like the correct lower radiator hose upper as well as heater core hoses. the fuse boxes and engine size harness power system is a little nicer than the 94 Cutlass stuff we used for the 442 so would probably be a little cleaner of an install to splice in the series to PCM and engine harness. repining the firewall pass through is not that difficult but it is tedious
    ~James~ Psychotic Gearhead
  7. #7 Re: swapping a supercharged motor to my 94 GTP?
    Oct 2014
    St Augustine FL
    For the donar car I would go with a 98 or newer. The 97 is a transition year with a unique PCM.
  8. #8 Re: swapping a supercharged motor to my 94 GTP?
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    find a decent parts car, buy the whole car. dont run back and forth to a junkyard
  9. #9 Re: swapping a supercharged motor to my 94 GTP?
    Banned
    Jan 2013
    Colorado
    it also won't be as simple as a bolt on intake or something like that which I feel like is what you are thinking. It's a little bit more in depth than that.
  10. #10 Re: swapping a supercharged motor to my 94 GTP?
    Oct 2014
    St Augustine FL
    Quote Originally Posted by camopaint0707 View Post
    This is true. The swap took me months to complete due to my inexperience and being an engineering student while working. I had several bugs to work out that took me many months after the car was running to resolve. Several cracked flexplates, failed torque converter, etc. I had the engine in and out of the car 6 or more times. It is completely do-able just not easy.
  11. #11 Re: swapping a supercharged motor to my 94 GTP?
    Aug 2012
    gladstone OR
    Agreed JamesIvey24, any thoughts on the best years to use?
  12. #12 Re: swapping a supercharged motor to my 94 GTP?
    Oct 2014
    St Augustine FL
    Quote Originally Posted by Kimbob View Post
    98-03
  13. #13 Re: swapping a supercharged motor to my 94 GTP?
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    Why?
    For how cheap 98+ GTPs are, you should just buy one of those.
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  14. #14 Re: swapping a supercharged motor to my 94 GTP?
    Aug 2012
    gladstone OR
    The nuts and bolts of swapping the engine and trans are not my concern. It's the electrical part that's got me worried. Knowing what to swap and how to connect it.
  15. #15 Re: swapping a supercharged motor to my 94 GTP?
    Aug 2012
    gladstone OR
    Drive XR7. I'm partial to the older body styles.?! Just buy it and drive it? BORING!!!!
  1. Swapping 02 motor into 98 body.
    By natethegreat in forum General Tech Discussion
    Last Post: 01-19-2014, 01:26 PM
  2. Motor swapping an L67 into another car
    By camopaint0707 in forum General Tech Discussion
    Last Post: 04-26-2013, 01:55 PM
  3. Motor and trans mount swapping
    By BillBoost37 in forum General Tech Discussion
    Last Post: 04-18-2013, 12:00 PM
  4. New to this 3.8 supercharged motor....
    By stereofreak1201 in forum Introductions/Noob Questions
    Last Post: 04-07-2013, 11:23 AM
  5. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
