Thread: Moog loaded front struts.
Results 1 to 20 of 25
  1. #1 Moog loaded front struts.
    SE Level Member Kaseyzgrandprix's Avatar
    Sep 2015
    utah
    Hey folks. So I picked up some moog struts for the front end, I noticed the bushings would have to be replaced by the end of this years so I picked up the loaded ones for a decent price. I knew it would sit high for a while but good grief man, looks like I'm bout sit down. I knew it would take a while for it to settle down and wear in but a month and its still high? Its dropped bout 1.5 inches. The springs were far from broken and could have been used again. I knew that when I put them in the garage when I washed and took that pick a month ago, even measured them Just to make sure for i am still wondering wth. Any ideas? And thanks for your time!
    Sent from my LGLS991 using Tapatalk
  2. #2 Re: Moog loaded front struts.
    Thats aftermarket parts for ya lol.
    4x4 status for dayzzzzzzzzz.
  3. #3 Re: Moog loaded front struts.
    Buffalo
    4x4? That looks like you're on bags and popped the front up
  4. #4 Re: Moog loaded front struts.
    If all 4 were done, it's 4x4.
  5. #5 Re: Moog loaded front struts.
    Buffalo
    shìt, what would you do? Replace the rears and hope it levels out?
    Cause those rims look big and not sure how lowering springs work with bigger rims
  6. #6 Re: Moog loaded front struts.
    Jan 2014
    AR
    If it still has sagging rears, the full weight has never been on the fronts yet. I bet if you jacked up the rear really high and left it on jackstands under the rockers like that for a weekend... with the rears hanging and the fronts smushed.... and bounce the front end every time you think about it over that weekend.... you might start to level it out.
  7. #7 Re: Moog loaded front struts.
    Sep 2015
    utah
    Its popping a wheely! It's bad enough that the lights had to be adjusted down a mile. Kept getting flashed, I'm close to changing the springs out. Also the first week or two I chewed on 2 tires and cracked a rim. It had been FAR below freezing for a couple weeks so they may have gotten a bit brittle combined with a stiff new strut and craters for potholes from the plows
  8. #8 Re: Moog loaded front struts.
    Bling bling
    04 Comp G.
  9. #9 Re: Moog loaded front struts.
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by REDCRAPGP View Post
    Bling bling
  10. #10 Re: Moog loaded front struts.
    Sep 2015
    utah
    I'm not ready to put the new rims on till theyre worn in if it will ever be so...
  11. #11 Re: Moog loaded front struts.
    Buffalo
    Dude fix the rears lol
  12. #12 Re: Moog loaded front struts.
    GTP Level Member
    Aug 2012
    st louis park, MN
    This happened to my 08 when I put 4 new KYBs on. Front never dropped. My only potential fault was I put in 04 quick struts because they didn't make them for the 08.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  13. #13 Re: Moog loaded front struts.
    Sep 2015
    utah
    Crazy guy those are almost 5 months old. And stocker is your 08 still sitting back? I am going to change out the front and MAYBE sell them for cheap idk. Irritating s#!t for sure. Those damn 20s used to look perfect i put the 18s on today n they are just too damn drastic. I'm going to have more parts collecting dust reminding me I'm far from perfect. Have a spare 3800 and trans waiting 2 sets of heads headers yada yada its ridiculous.
  14. #14 Re: Moog loaded front struts.
    Buffalo
    They make cargo springs for the rear to bring it up.
    Or use a a correct set of lowering springs between the GTP and intrigue. That should
    level it out depending on what way you want to go
    reason I mention both is in case 20s rub with a lowering spring.
  15. #15 Re: Moog loaded front struts.
    Sep 2015
    utah
    It would help the look of the 18x8s though that's a good idea thank You very much!
  16. #16 Re: Moog loaded front struts.
    Enfield, CT
    Put the 06+ plus springs in the rear. They are the same as Intrigue springs and should help.
  17. #17 Re: Moog loaded front struts.
    Sep 2015
    utah
    My issue is I have some ar904 rims with way nice rubber I've been dying to put on but with the car sitting like that it looks like I have hydros all cholo style with little wheels. Not my style lol they look to small bro and I just dropped about a grand for wheels n rubber. The mrs keeps *****ing "why are the new rims in your too doo pile??" fu#!ing irritates me.
  18. #18 Re: Moog loaded front struts.
    Buffalo
    Do you want the front as low as the rear or the rear as high as front ?
  19. #19 Re: Moog loaded front struts.
    Buffalo
    Lol cholo
  20. #20 Re: Moog loaded front struts.
    Sep 2015
    utah
    Vatos locos forever essay! Lol I def want the front to settle back down
  1. Front Struts
    By Speedy1973 in forum Wanted To Buy - Parts
    Last Post: 04-06-2014, 11:33 AM
  2. 05 Front Struts
    By jkazam1 in forum Brakes/Suspension/Chassis
    Last Post: 03-29-2013, 03:28 PM
  3. GMPP Front Loaded Struts
    By booch in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2013, 04:41 PM
  4. Front Struts
    By GPSims39 in forum Brakes/Suspension/Chassis
    Last Post: 05-14-2009, 08:32 AM
