Thread: Heater Core or Not?
Results 1 to 13 of 13
  1. #1 Heater Core or Not?
    Jan 2016
    USA
    Good Morning! Yesterday I got into my Pontiac Grand Prix GT 2004 3.8 Series 3 Engine after letting it warm up and it was leaking water on the passenger side floorboard. My heater is producing warm air no problem, but my windows are steaming up and water all over the floor. Is this my heater core or could there be another problem? If I can avoid changing the heater core that would be great but its probably not my luck.
  2. #2 Re: Heater Core or Not?
    need to see if its coolant, if it s coolant your changing the core.
    you can bypass the core till you get a new one.
  3. #3 Re: Heater Core or Not?
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    I had a similar issue after I had the windshield replaced...Water on passenger side...
    Appears they forgot to replace the seal correctly and all I had to do was push it in place, iirc...
  4. #4 Re: Heater Core or Not?
    GXP Level Member
    Mar 2015
    Tomball
    If you park on an incline, or if it's been raining recently and it's not coolant you may just have a plugged drain. I had that happen earlier this year and had to unplug it.
    Jeff
  5. #5 Re: Heater Core or Not?
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Smell it. You will know if its coolant or not. Speaking of a plugged drian, I need to clean mine...
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  6. #6 Re: Heater Core or Not?
    Jan 2016
    USA
    Quote Originally Posted by cmayle0724 View Post
    Good Morning again! Yes it is coolant, and the passenger side is soaking wet. Windows are all steamed up! Looks like Saturday I'm changing the core! Not looking forward to taking the whole dash and console apart! Thanks for everyone's help!!
  7. #7 Re: Heater Core or Not?
    GXP Level Member
    Mar 2015
    Tomball
    So I guess you are saying it smells and is sticky like coolant as well?
  8. #8 Re: Heater Core or Not?
    Sacramento, CA
    This guy did it without pulling the dash...
    https://www.youtube.com/watch?v=VuQ078KHX0U
    Hope this helps...
  9. #9 Re: Heater Core or Not?
    dash stays in. its just a lot of back and forth side to side removing little gold screws.
    console has to come, seats can come out or not. depends on how much room you need
  10. #10 Re: Heater Core or Not?
    Jul 2010
    Coquitlam,BC,Canada
    Your heater core will leak coolant. If you have water on the floor, it is coming from outside the vehicle. Unless you have water in your cooling system.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Heater Core or Not?
    Jan 2016
    USA
    Good Morning!
    Yes it is coolant! It's sticky and smells like coolant. No heat this morning! Froze on my way to work! I will watch the You Tube video and hopefully there is a easier way then pulling the dash. I have to wait till Friday when I get paid before I can buy the new heater core. All I can say at this point is I hope it warms up! Again thank everyone for their help!!!
  12. #12 Re: Heater Core or Not?
    make sure you keep the rad full. take the hoses off the fire wall and loop the alt bracket coolant ports. this whay it stops leaking, and the coolant stays full.
  13. #13 Re: Heater Core or Not?
    Jan 2016
    USA
    Thank all of you! I will be changing this Saturday morning and will let you all know what happens. Christa
  1. heater core
    By dlk in forum General Grand Prix Discussion
    Last Post: 04-22-2014, 06:29 PM
  2. need help heater core
    By PDUBC in forum Introductions/Noob Questions
    Last Post: 05-17-2013, 06:05 AM
  3. Heater core
    By jase711 in forum General Tech Discussion
    Last Post: 02-18-2013, 01:29 PM
  4. heater core
    By jase711 in forum Introductions/Noob Questions
    Last Post: 02-18-2013, 12:22 PM
  5. Heater Core?
    By GrandPrixgtp2000 in forum General Tech Discussion
    Last Post: 06-21-2012, 04:33 PM
