Thread: Wanna help diagnose this?
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Wanna help diagnose this?
    you dont want to delete misfire codes. deleting a code really only keeps it fom setting the code, the issue still remains. aka you still felt the misfire.
    good to hear wires fixed it up too. nice and simple.
  2. #22 Re: Wanna help diagnose this?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Quote Originally Posted by ScottyDoggs View Post
    I didn't delete any misfire codes, just the 1610 and the last one.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  3. #23 Re: Wanna help diagnose this?
    rodger that.
  4. #24 Re: Wanna help diagnose this?
    Aug 2011
    Gahanna, Ohio
    shirley you must be kidding.
  5. #25 Re: Wanna help diagnose this?
    Quote Originally Posted by buck531 View Post
    no im not, and stop calling me Shirley.
    ever see a grown man necked?
  6. #26 Re: Wanna help diagnose this?
    Banned
    Jan 2013
    Colorado
    got a pic of the no interior?
  7. #27 Re: Wanna help diagnose this?
    Aug 2011
    Gahanna, Ohio
    this.
    I was hoping you'd catch on .
  8. #28 Re: Wanna help diagnose this?
    Aug 2011
    Gahanna, Ohio
    Quote Originally Posted by camopaint0707 View Post
  9. #29 Re: Wanna help diagnose this?
    Aug 2011
    Gahanna, Ohio
    So.. I replaced the BCM from one at pick n pull and also replaced the PCM and did a full write on it. Same issue.
    Here's a video of the car cutting out (and actually stalling). ugh. Friend of mine suggested the ignition switch?
    https://www.youtube.com/watch?v=EzclhrvvO6I
  10. #30 Re: Wanna help diagnose this?
    hows the fuel pump? thats what mine would as it saw fit when it went bad.
  11. #31 Re: Wanna help diagnose this?
    Aug 2011
    Gahanna, Ohio
    Yeah I remember you said fuel pump before. It seems fine? The thing that's crazy is the fuel theft deterrent code and the other bcm serial data code. The electronic braking code I'm not that concerned with. I was hoping it wasn't the fuel pump but on the other hand I hope it is because I was going to go corn in the spring so I would have to change the pump anyways.
    Did you see in the video where the tach jumped? Just seems odd to me.
  12. #32 Re: Wanna help diagnose this?
    mine did the tach jump crap too. its like its fighting to run. next time its stalls, pull over, leave the key to run see how much pressure is in the rail. just pushing the shrader pin in on mine and the gas spit out, but like a limp dick cuming lol
  13. #33 Re: Wanna help diagnose this?
    Aug 2011
    Gahanna, Ohio
    I'll try that next time I drive it.
    What about the codes? I find it hard to believe that it might be the fuel pump throwing those codes but maybe I'm wrong.
  14. #34 Re: Wanna help diagnose this?
    not sure but mine tossed up a icm and crank code after i changed the harness and the crank sensor. since the new pump, zero issues.
  15. #35 Re: Wanna help diagnose this?
    Aug 2011
    Gahanna, Ohio
    Finally found something on google.
    http://www.hotrodlane.cc/New%20LT%20...nal%20Lost.htm
    Did I mention I hate wiring/electrical issues?
    Guess I'll take off the ignition switch and see if I can figure out if there are any issues with it.
  1. Help Diagnose my clunk
    By hshift in forum Brakes/Suspension/Chassis
    Last Post: 07-03-2014, 05:53 AM
  2. I can't diagnose what's wrong with my car
    By metalexa1 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-03-2012, 05:21 PM
  3. Diagnose my problem please
    By skeelo58 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2010, 12:21 AM
  4. Impossible To Diagnose
    By 01Romano in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 06:19 PM
