Thread: Grand prix ram air
Results 1 to 10 of 10
  1. #1 Grand prix ram air
    Nov 2010
    Ray MI
    I have a GTX ram air hood that I want to put on my GTP. I currently have a Wizzair CAI on the car. I was thinking I could cut a hole in the top plastic, and then use a piece of foam to to connect it to the opening in the underside of the hood. Has anyone else done this? I think this could work.
    http://www.ebay.com/itm/1-OEM-GM-SLP...pTa83S&vxp=mtr
    This is what I what to do, but I don't have a GTX air intake.
    This is what I have now.
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  2. #2 Re: Grand prix ram air
    SE Level Member l36grandprix's Avatar
    florida/ohio
    As long as the hole in the hood lines up. I have thought about it myself with my slp hood. I don't think it will help much though. The supercharger will pull air in anyway.
  3. #3 Re: Grand prix ram air
    Nov 2010
    Ray MI
    You are probably right it won't make much of a difference. I just think it would be cool.
  4. #4 Re: Grand prix ram air
    Feb 2010
    TN
    Here's what you do, get that piece of foam ( you can buy it on ebay or from GM by the way) attach it to the hood, put a thin layer of Vaseline, or grease or water soluble paint on the other side of the foam. Close the hood, after a few seconds open the hood. Look at the wizard air, you now know exactly where to make the hole so it lines up.
  5. #5 Re: Grand prix ram air
    Nov 2010
    Ray MI
    Great advice. I think that will be the best solution when it comes to drilling/cutting.
  6. #6 Re: Grand prix ram air
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I'd go for it. You already have the hood so might as well make it functional. It probably won't help very much but it definitely won't hurt anything.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  7. #7 Re: Grand prix ram air
    Kemmerer, Wyoming
    cold air is cold air. air pulled in from outside the engine bay is always going to be better than air heated by the engine. but either way, the supercharger is going to heat the air, so how much difference it makes is up for debate.
  8. #8 Re: Grand prix ram air
    Jan 2014
    AR
    How will you keep the air filter from getting soggy? Also I kinda wonder if there won't be low pressure right there rather than high. I'm cool with the idea, as long as the hood structure isn't compromised.
  9. #9 Re: Grand prix ram air
    Nov 2011
    NY
    Quote Originally Posted by SgtMarshal View Post
    Actually debate is not needed, it has been studied and postings made, you just have to search for the information, it's out there. Not that it wouldn't lower intake temps as it does, the heat soak of the SC offsets any potential gain, let alone if you're dropping pulley sizes and having the SC spin at speeds above normal. Then the heat generation is even greater
    colling air, cooling fuel, snout cooling, cooling cooling has all been tried... Best effect is cooling air POST SC, ie, Intercooler... But yeah, in a very, very small way, outside air is better than air from under the hood.
    ... as for the OP, have you considered a side vent in the drivers fender? They're readily available and a fender more espasily workable and replaceable should it not work well or look like crap.
  10. #10 Re: Grand prix ram air
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    I just took the top off of my wizaired, noticeable difference in sound, that's for sure. I have a ram style hood and the hole is right above the intake anyways
  1. 2004 Grand Prix Comp GTP Rear Fenders/Quarters and Grand Prix Parts***
    By luckydogaroo in forum General Grand Prix Discussion
    Last Post: 01-30-2015, 04:00 PM
  2. Replies: 23
    Last Post: 06-21-2013, 12:52 PM
  3. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  4. 1991 grand prix 3.1 swap into 1996 grand prix 3.1
