So how can we fix the problem as cheaply as possible. I know. Instead of fixing the leak we will move the wires so it will drip on the ground instead of down to the manifold. Now several thousand more NTSB complaints, few more car fires, few more deaths. Hey I know how we can fix it. Rather then replace the gaskets, cause hey that's too expensive, why should we do things right, let's just remove everything out of the way that can catch fire.
Same with the ignition recall. Wait. Rather then replace a defective ignition switch let's just prevent people from using their key ring. Why fix the actual problem when you can just half a$$ the repair!
Don't you just love GM! Shows you that money matters more then people's lives.
Well in actuality all car manufactures recommend not having a giant ring of keys as this does put unaccounted strain on the ignition switch.
