Thread: 2007 base 3.8 HORN does not work at all
Results 1 to 3 of 3
  1. #1 2007 base 3.8 HORN does not work at all
    Dec 2014
    Horn does not chirp when you hit the lock button on keyfob or when you press the steering wheel in. Swapped both the horn fuse and relay no dice. Took the horn out and tested it on a power supply and it sounds fine. At this point I'm suspecting it's a wire issue but the wires look fine from horn connector to the plastic hose where 700 other wires reside which then goes into the fusebox. Any ideas? I can hear the relays clicking in the fuse box so I think wiring is good from battery to fuse box.
  2. #2 Re: 2007 base 3.8 HORN does not work at all
    pop the air bag off and check the horn wires, it may have popped out, it its corroded maybe.
  3. #3 Re: 2007 base 3.8 HORN does not work at all
    after thinking more, test for power at the horn plug when you push the horn on the wheel. maybe its just a dirty plug.
  1. horn doesn't work
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2014, 11:21 PM
  2. How can you make the horn work with the key fob?
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 12-08-2012, 12:51 PM
  3. Horn doesn't work, any help?
    By hockeybawler in forum General Tech Discussion
    Last Post: 10-10-2012, 10:30 PM
  4. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  5. Help! My horn doesnt work...
    By 97gtpprix in forum Audio, Security & Visual Electronics
    Last Post: 08-18-2010, 04:08 PM
