Thread: No sound from speakers
Results 1 to 7 of 7
  1. #1 No sound from speakers
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I started my 01 with Bose in it. I have aftermarket CD player in it as well. Anyway I took it for a drive, started fine, the CD player made the beep sound when I plugged my phone into the usb. But no sound was coming, I thought it was just turned down but no sound.
    I tried my cd, radio, and the usb and no sound. Was hoping to take it for the trip to North Dakota but took my g6. I checked the 20 amp fuse for the amp and it was not blown, that's all I checked before I left for my trip. Anyone have a idea on what's wrong? I checked the wires that plug into amp and it was good.
    EDIT: FIXED CAR JUST NEED A TAMPON
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  2. #2 Re: No sound from speakers
    GXP Level Member
    Mar 2015
    Tomball
    Is the amp turning on?
    What amp are you talking about a factory or aftermarket?
    Was the amp on (little light or something)?
    Could you have accidentally hit mute?
    All the other questions require a meter so let us know when you are back and we'll troubleshoot it.
    Jeff
  3. #3 Re: No sound from speakers
    Aug 2012
    Brainerd, MN
    Its factory bose amp in the trunk, I am not positive if it was on or not, i tried hitting mute, then unmute, to no avail. Where is the light supposed to be on at? I don't recall ever seeing a light on the stock bose amp being on, but I could be wrong. Im assuming either the amp took a poop, or a fuse or not getting enough power somehow. I disconnected the battery cable and reconnected being leaving yesterday and nothing.
  4. #4 Re: No sound from speakers
    GXP Level Member
    Mar 2015
    Tomball
    Did you just install that aftermarket CD player? Was it working before?
  5. #5 Re: No sound from speakers
    Aug 2012
    Brainerd, MN
    I installed the cd player about two years ago now, its kind of something that happened out of no where. I disconnected the subwoofer power cable about two months ago it was smelling hot, i am not sure if it was the subs or my amp, or the stock amp. But did not smell hot after i did that. The speakers always worked, this is the first time I have had any problems.
    Does anyone know if there is any more fuses for the stock amp, or anything related to check? I am going to look at the car tomorrow, check the stock power cable, i checked the one 20 amp fuse for the stock amp, and it was not blown, the car didn't do anything, I drove it the day before, parked it, and then started it ready to take a trip in it and no sound.
  6. #6 Re: No sound from speakers
    GXP Level Member
    Mar 2015
    Tomball
    With the stock amp in there I'm not sure, but I would look for a schematic to check for power on the amp. Stock amps typically don't have an LED. Does it still make the beep sound? If not then the amp may have just failed.
    Jeff
  7. #7 Re: No sound from speakers
    Aug 2012
    Brainerd, MN
    The beep sound is coming from my head unit..
    My car has a mind of its own, i went and looked at it today, i unplugged the cords to the amp, and re plugged them back in, i also reset the computer, removed battery cable for a good hour or two, then went back out hooked it back up, and then there is sound.
    Not sure what was the problem, but its working fine now..my cars time of the month
    Cords to the amp were plugged in, i just took them off, and put them back on, same with the battery cable, positive cable was on there nice and snug. Nothing was unplugged, loose, just figured I would try that before i start getting into it more.
  1. No sound from front speakers? 2003 gtp Bose system
    By grdn24 in forum Audio, Security & Visual Electronics
    Last Post: 05-14-2014, 05:24 PM
  2. Hissing sound coming from rear speakers.....
    By p coico in forum Audio, Security & Visual Electronics
    Last Post: 01-20-2013, 02:46 PM
  3. front door speakers sound distorted
    By tod1d in forum Audio, Security & Visual Electronics
    Last Post: 06-15-2012, 06:23 AM
  4. No Sound From Speakers
    By Tim Foolery in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2012, 01:44 PM
  5. Cant's get any sound out of my speakers on my 2000 GTP
    By buickman104 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2011, 11:13 PM
