Thread: New Plugs
Results 1 to 5 of 5
  1. #1 New Plugs
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    New Autolite 104s gapped to .050. Ones that came out looked like there were originally gapped to .050 but measures .052 ish reflecting wear.
    Old plugs:
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  2. #2 Re: New Plugs
    Otherwise they look just fine to me.
  3. #3 Re: New Plugs
    How many miles?
    I put close to 22k~ on my AL103R's on my Thrasher motor.
    For all those people that said 103/4's only last like two oil changes.
  4. #4 Re: New Plugs
    Dec 2008
    ****'s Creek
    Not sure...just bought the car in August and have been doing routine service. Also was suggested that I check plug gap at .050" to eliminate a little KR at WOT. I figured if I'm going to take the trouble to pull the plugs and gap them, I may as well replace them.
    The plugs themselves look good, not fouled at all, what caught my eye is how rusty the outsides are....I have never seen plugs rust like that on the outside.
  5. #5 Re: New Plugs
    Mainly because the wires only cover the white and that the plugs do stick out of the head pretty far. Aswell as them being able to see road splash/condensation.
    And kinda because the AL brand isnt like some NGK's/delco plugs that I think have a protective coating on the outside, I've seen some delco plugs look pretty good still after many years.
  1. Platinum Plugs vs. Iridium Plugs
    By Eddie Jackson in forum 5.3L V8 (LS4)
    Last Post: 10-17-2012, 10:55 AM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. Plugs??
    By Rudd97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 07:01 PM
  4. Plugs
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2011, 05:06 PM
  5. what plugs and gap should be used?
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2010, 11:20 AM
