Thread: 97 gtp chugging issues and backfires
Results 1 to 11 of 11
  1. #1 97 gtp chugging issues and backfires
    Dec 2010
    DMV
    Posting for a buddy.
    Car has been chugging and randomly cutting off lately.
    Car stalled and shut off yesterday. Got it towed home and trying to start it and Lights dim and volt gauge shows 14 at key on. Tried to start it and no luck. Exhaust backfired.
    Car has no catalytic converter as well.
    Gas can be smelled when exiting the car. Engine code for short on cylinder 3 injector wire. Snagged another connector and wire for the injector.
    Used the multimeter to check power at the injector connector and it has it.
    Cylinder three shows 2155 misfire history.
    Any idea what it could be?
    Check vacuum lines and those were good.
    Unplug the maf and that made no difference.
    Stumped.
  2. #2 Re: 97 gtp chugging issues and backfires
    Topeka, KS
    Does it go wooo wooo after it chugs? What's the afr like. Sounds rich if you smell gas. Possibly stuck injector. Changed plugs? First thing id do for a misfire. Does missfire change cyl if you swap wires with another cyl. Cleaned all coil pack terminals?
    Sent from my SCH-I545 using Tapatalk
  3. #3 Re: 97 gtp chugging issues and backfires
    Dec 2010
    DMV
    Chugs at low rpms. Car gas had an constant misfire since the tune up a few months ago. Cylinder three wire had got damaged while resting on the plog. He replaced it with a wire from the Junkyard Lmao. Gonna swap plug with different cylinder tommorow
  4. #4 Re: 97 gtp chugging issues and backfires
    Topeka, KS
    Plugs can be bad. Replace it. Plugs are cheap. And replace the wire with a new one.
  5. #5 Re: 97 gtp chugging issues and backfires
    Dec 2010
    DMV
    Thanks I'll update tommorow
  6. #6 Re: 97 gtp chugging issues and backfires
    Dec 2010
    DMV
    This idiot didn't have gas. Smh.
  7. #7 Re: 97 gtp chugging issues and backfires
    Wow lol
    04 Comp G.
  8. #8 Re: 97 gtp chugging issues and backfires
    Dec 2010
    DMV
    Yes. Three days after I asked him did he have gas. Smh
  9. #9 Re: 97 gtp chugging issues and backfires
    lol yeah gas is kinda needed for a engine to run........
  10. #10 Re: 97 gtp chugging issues and backfires
    Jan 2014
    AR
    lol.
  11. #11 Re: 97 gtp chugging issues and backfires
    Topeka, KS
    Of F a duck man. Really?!?! Lol
  1. 04 chugging issues
    By Travisgt2 in forum Engine
    Last Post: 03-03-2015, 11:42 PM
  2. chugging
    By Scottydoggs in forum General Tech Discussion
    Last Post: 08-20-2012, 12:41 PM
  3. Wont run and backfires
    By spow1998 in forum General Tech Discussion
    Last Post: 06-06-2011, 09:23 AM
  4. Chugging
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2011, 08:02 PM
  5. chugging
    By davisg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2011, 06:01 AM
