Thread: How to remove map light/sunroof bezel?
Results 1 to 3 of 3
  1. #1 How to remove map light/sunroof bezel?
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    The buttons that control the map lights suddenly won't work. It's as if the circuit board that controls the buttons has come loose from the bezel, I.e. the buttons push and don't do anything. How do I remove the panel to check it out?
  2. #2 Re: How to remove map light/sunroof bezel?
    Jul 2010
    Coquitlam,BC,Canada
    I think yours will be different, but here are some images of a non-sunroof light removed.....
    http://chrisb.users.superford.org/Gr..._Lighting.html
    Might help until somebody else posts up? 2 tabs at the rear of the housing hold it in place.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: How to remove map light/sunroof bezel?
    Feb 2009
    Roanoke, VA
    Alright I got the assembly out! The problem I'm having is both buttons stopped working, like they were free moving, not clicking to turn the lights on or off. Inside the unit are the two switch boxes and for some God awful reason they both decided to pop apart at the same time. Is there something that's supposed to hold the two halves together or do I just have to glue it and pray?
    http://imgur.com/qumGtEI
  1. Best way to remove sunroof
    By 04lss in forum General Tech Discussion
    Last Post: 10-27-2014, 09:52 AM
  2. How do i remove driverside mirror control knob from bezel
    By mediaguy in forum General Tech Discussion
    Last Post: 02-25-2012, 10:48 AM
  3. 97-03 Sunroof Maplight Dome Trim Bezel - Help Install
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 12-26-2011, 10:55 AM
  4. How do I remove sunroof switch trim
    By SnowDrift in forum General Tech Discussion
    Last Post: 05-19-2011, 06:55 AM
