Thread: Please HELP!!
Results 1 to 10 of 10
  1. #1 Please HELP!!
    Nov 2015
    Odessa Tx
    Hi I've got a 2004 Pontiac Grand Prix GP 3.8 non turbo, I'm having problems with it starting.. I've got power to the fuse box but not to anything else.. When I turn the key, the radio and accessories come on but the car won't crank over due to no power to starter solenoid...
  2. #2 Re: Please HELP!!
    Kemmerer, Wyoming
    did you check to see if your battery is dead?
  3. #3 Re: Please HELP!!
    Bad battery or loose/bad cables.
    Also, thread titles like this make almost not want to help. They just want attention quickly, coulda made it more about the issue instead.
  4. #4 Re: Please HELP!!
    Feb 2013
    37.295091, -121.930053
    battery is were i would start. if your starter is going try hitting it with a hammer it should wake it up
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Please HELP!!
    your testing the small wire on the starter with the key turned to crank? thats the only time the little wire has power, that wire is what tells the starter to work.
  6. #6 Re: Please HELP!!
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Btw no grand prix is stock turbo. They only come factory with a super charger or nothing at all. At least no 97+ did. Don't know about anything older.
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  7. #7 Re: Please HELP!!
    Last turbo GP was back in like 89-91??
  8. #8 Re: Please HELP!!
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    I don't have a turbo either
    1999 Buick Regal "Betty White"
    NIC Cam FSIC E85 Built Trans Flaky Paint
    Ported Aluminum Coolant Elbows
  9. #9 Re: Please HELP!!
    Nov 2015
    Odessa Tx
    I meant non supercharger guys, my bad! Battery is brand new. Yes I tested it while someone was trying to crank it, the starter is good cause I can use a jumper and it'll crank. My problem is that I don't have power to anything besides accessories when key is turned on.
  10. #10 Re: Please HELP!!
    try swapping the starter relay if you have one listed.
    will it run when you jump the starter?
