Thread: Problems with Forum
Results 1 to 7 of 7
  1. #1 Problems with Forum
    GTP Level Member tms8582's Avatar
    Washington Michigan
    When I post on a newer thread it does not appear on the near the top of the "new posts" and most of the time I can't find it at all? Unless I stay subscribed to the thread I can't find it a lot of times??? I don't always want to stay subscribed bc my e-mail gets so many e-mails. The old user panel used to have a "all posts by user" button and I can't find this on the new version. Anybody else notice these problems?
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  2. #2 Re: Problems with Forum
    Pennsylvania
    Forum Actions > General Settings > Default Thread Subscription Mode: Through my control panel only > Save Changes
    Then you can be subscribed to as many threads as you like without receiving e-mails and access them through Quick Links > Subscribed Threads
  3. #3 Re: Problems with Forum
    Washington Michigan
    Thanks I was thinking about making that change but want to receive e-mails sometimes... Still miss that feature from before and the new posts are not accurate at all...
  4. #4 Re: Problems with Forum
    Omaha, NE
  5. #5 Re: Problems with Forum
    Pennsylvania
    Okay, so coming back to this: I am still receiving emails about subscribed threads, despite my Thread Subscription Mode being set to "Through my control panel only."
    So, clearly, this is broken.
  6. #6 Re: Problems with Forum
    if you subscribed to them before you switched that over you'll still get e-mails. You have to go through to every thread you sub to before you changed it and change them all.
  7. #7 Re: Problems with Forum
    Pennsylvania
    Smart lad.
  1. new to the forum and having problems with the pass key system
    By destiny4u in forum General Tech Discussion
    Last Post: 09-21-2011, 01:20 AM
  2. New to forum
    By JimJimSpa in forum Introductions/Noob Questions
    Last Post: 05-02-2010, 10:29 PM
  3. New to Forum
    By hefaus in forum Introductions/Noob Questions
    Last Post: 05-21-2009, 08:58 AM
  4. new to forum-having HID problems
    By LMCOOK87 in forum Introductions/Noob Questions
    Last Post: 06-10-2008, 11:09 PM
  5. Forum Problems
    By 19SE92 in forum Forum Bugs/Suggestions
    Last Post: 03-15-2008, 12:24 AM
