Thread: Source or P/N for Rubber LIM Vacuum Tee under SC Snout?
Results 1 to 5 of 5
  1. #1 Source or P/N for Rubber LIM Vacuum Tee under SC Snout?
    Cliffside Park, NJ
    Does anyone know of a source or P/N for the rubber LIM vacuum tee under the SC snout? The dealer sells it with other parts for around $26.
    Thanks, Joe
  2. #2 Re: Source or P/N for Rubber LIM Vacuum Tee under SC Snout?
    Banned
    CT
    IMO your best bet is to just buy the whole shebang from the dealer. Unless it's on rockauto for cheaper. I had to replace mine a few years ago and I tried cheaping out at first with vacuum lines and tees from Napa, but it looked like crap and I had leaks.
  3. #3 Re: Source or P/N for Rubber LIM Vacuum Tee under SC Snout?
    GT Level Member sic6's Avatar
    san marcos, tx
    The HELP section in your local auto parts store should carry it.
  4. #4 Re: Source or P/N for Rubber LIM Vacuum Tee under SC Snout?
    Cliffside Park, NJ
    "The HELP section in your local auto parts store should carry it." I tried the HELP sections at R&S Strauss, Advance Auto, and AutoZone plus I checked the Dorman catalog without success. Do you remember where you saw the part? Thanks, Joe
  5. #5 Re: Source or P/N for Rubber LIM Vacuum Tee under SC Snout?
    Jul 2010
    Houston, Texas, United States
    Quote Originally Posted by Joe942 View Post
    I redid all of mine with small vac line with a hair bigger vac t barbed fittings. Over a year ago now zero issues.
    Or zzp has a silicone hose with brass t fittings.
    Hope this helps.
  1. Switched Ignition Source
    By Blackhawk in forum Audio, Security & Visual Electronics
    Last Post: 11-15-2009, 05:51 PM
  2. 12volt switched source?
    By nyydmb12 in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2009, 06:45 AM
  3. GMPP Warranty source
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 10-06-2009, 11:37 AM
  4. Antifreeze in Oil - How to determine the source.
    By warrenz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2009, 10:10 AM
  5. Most likely source for coolant leak?
    By nlinesk8s in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 08:09 AM
