Thread: What engine to Swap, 2021
Results 1 to 6 of 6
  1. #1 What engine to Swap, 2021
    Apr 2021
    Riverside, CA
    Hey everyone,
    I just had my N/A 3800 series II engine go out in my 97' grand prix. I was wanting to do an engine swap and it seems like my options are are follows:
    - 3800 N/A
    - 3800 Supercharged
    - LS4
    I was hoping for any opinions to help with my decision making and maybe someone's first had experience.
    I have done work on cars before and am comfortable with turning wrenches. I do want to make some more power out of my car once done but don't want to spend months on the process. Right now I am leaning toward trying to put in a L67.
    Thanks for any help.
  2. #2 Re: What engine to Swap, 2021
    97's with the NA engine run a vacuum like down to the transmission and those are generally the weakest because it's a 4T60e where as the next year later they are 4T65's. You'd need to swap in a 4T65e-HD transmission if you really want this to work, then run a L67 computer.
  3. #3 Re: What engine to Swap, 2021
    Apr 2021
    Riverside, CA
    Wow, yeah, I totally forgot about that vacuum line. Guess I will need a transmission too. Do you know if the boost display in the car will work, or is there something special I have to do to hook that up. Any other comments would be great too.
    Thanks
  4. #4 Re: What engine to Swap, 2021
    GT Level Member mguzzo's Avatar
    Buffalo NY
    if the car's worth saving and modding, drop in a 98-2002 L67 including trans and harness. This combo would be easiest to mod and tune and you avoid the idiosyncrasy of the 2003+ PCM / trans.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: What engine to Swap, 2021
    Mar 2014
    Tucson
    Is emissions testing an issue?
  6. #6 Re: What engine to Swap, 2021
    Apr 2021
    Riverside, CA
    Yes, sadly. Im in CA so it has to be smogged every 2 years. The last time I got it tested was 3 months ago so I have a while, but I hope on keeping the car. Everything else is in good shape.
    Any tips on buying a used engine?
    good websites or anything like that?
  1. Which lowering springs to get in 2021?
    By dirtyape in forum Brakes/Suspension/Chassis
    Last Post: 06-01-2021, 09:41 PM
  2. Engine swap / Trans swap 2001 gtp v. compatible years
    By Banana Hammock in forum General Grand Prix Discussion
    Last Post: 07-06-2016, 08:27 AM
  3. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  4. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
