Thread: 2000 gtp starting issues.
Results 1 to 4 of 4
  1. #1 2000 gtp starting issues.
    Nov 2016
    Grand Rapids
    I have a problem with starting engine last night. Mobile mechanic look to engine and cannot found something wrong, he say needed to see car in shop.
    Sorry for my english, maybe on this video record you can found problem reason with start? Thanks!
    In tube in front of engine fuel available.
  2. #2 Re: 2000 gtp starting issues.
    Just to check the MAF and to perhaps rule it out, unplug the Mass Airflow Sensor (MAF) on top of the throttle body and try starting it.
    You may have to pedal it to life a little and if it starts without it, you may have a bad MAF sensor. If it does start and you plug the MAF back in and try starting it again and it doesn't, then it's the likely failed part.
    You say you have fuel pressure at the fuel rail so that's good.
  3. #3 Re: 2000 gtp starting issues.
    Nov 2016
    Grand Rapids
    Thank you, i will try in monday.
    http://troubleshootmyvehicle.com/gm/...e-maf-sensor-1
  4. #4 Re: 2000 gtp starting issues.
    Nov 2016
    Grand Rapids
    It was broken fuel pump.
  1. 08 GP starting issues
    By bluebsh in forum General Grand Prix Discussion
    Last Post: 11-21-2015, 04:55 PM
  2. Starting Issues
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2013, 01:56 PM
  3. Starting issues.
    By SchylerC in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-14-2013, 09:44 PM
  4. 2000 Grand Prix GT starting issues
    By Ponticaconfused in forum General Tech Discussion
    Last Post: 01-03-2013, 12:25 AM
  5. starting issues
    By bdm72 in forum Introductions/Noob Questions
    Last Post: 12-10-2012, 12:48 AM
