Thread: Pontiac Grand Prix HID Conversion Kit! Plug & Play Installation!
Results 1 to 20 of 137
Threaded View
  1. #1 Pontiac Grand Prix HID Conversion Kit! Plug & Play Installation!
    Donating Users Paul J McCain's Avatar
    St. Louis, MO
    Pontiac Grand Prix HID Conversion Kits
    This kit has been carefully designed from the ground up to be the highest-quality HID kit available on the market, without exception.
    Ballast: The ballasts are the most important component of an HID kit, as they provide the power. After years of providing midrange and high-quality ballasts for vehicles of all makes and models, Diode Dynamics learned what was important in making a good ballast, and applied it when designing these.
    Controller Chip. Most digital (DSP) ballasts on the market still use generic chips, which are cheap, and work pretty well. However, when you need maximum quality, you need a new computer chip designed for one purpose. This is known as an Application-Specific Integrated Circuit (ASIC). These ballasts use brand new DSP ASIC chips for maximum efficiency and brightness, fast warmup time, and extremely stable operation.
    CAN-BUS. Some vehicles have systems which sense the power consumption. Since HIDs use less power than factory halogen bulbs, this can cause issues. You can resolve this by adding capacitors, known as warning cancellers, or some ballasts come with them built-in. However, sometimes that's still not enough to trick the vehicle! To fix it, this ballast has not one, but two CAN-BUS modules, which provide capacitance and resistance to the circuit to defeat even the most troublesome modern CANBUS systems. Even if your vehicle does not use a CAN-BUS system, these modules will provide extra power smoothing for reliable operation. Simply put, this ballast will work on any vehicle, the first time you plug it in. With this kit, you don't need to worry about capacitors, warning cancellers, or resistors.
    Igniter and Startup. You may have heard of ignition issues with other ballasts, caused by an igniter that is too small to withstand cold temperatures. No reason to worry with these ballasts- the oversized 24kV external igniter means that you will never have an ignition issue, even in the coldest temperatures. Additionally, the ASIC chip in these ballasts means that you only need 4 amps at nominal voltage to start up. These ballasts consume less power than any other on the market, meaning 100% reliable and fast startups, every time.
    Shielding. Ever noticed a little black plastic thing clipped onto your laptop charger cord? That's a ferrite bead, which is used to suppress high-frequency signals, which can create radio interference. All ballasts generate these signals, and most just have protection in the ballast. We've also included ferrite beads on the wire, to suppress them.
    LED Indicator. Convenience is key, especially during installation. To make things easy, we've added an indicator LED on the input wire, so you know that the ballast is getting power.
    Case. These ballasts are the smallest you will find, about the size of a pack of playing cards. The case is fully potted, or filled with epoxy, which makes them fully waterproof and shockproof. Most ballasts on the market are filled to some degree, but these are completely filled to the top, sparing no expense to ensure longevity.
    Bulbs:
    The bulbs included with Diode Dynamics kits are CNLight bulbs. CNLight is the top manufacturer of aftermarket bulbs in the world, providing the best quality available. You might see other high-quality kits on the market which also use CNLight bulbs. They provide superior life, brightness, and color attenuation when compared to generic HID bulbs, like those found in most cheaper kits on the market. The one-piece base design prevents any issues with separation over time, making the entire bulb extremely reliable.
    The CNLight bulb temperatures are rated accurately in Kelvin temperature at 35W, and have an industry-standard 3000 hours of estimated bulb life, which should outlast your vehicle. Please be aware that most HID bulbs are rated inaccurately from other manufacturers. 8000K is not dark blue, and 6000K is not pure white! We provide accurately-measured colors. 3000K is our lowest temperature, and has a pure yellow output, which is great for use in fog lights. 4300K is a pure white output, as seen on many factory HIDs. It will not have any blue tint to its color, and might appear slightly warm. 6000K is our most popular color, which produces an ice white color. It has a very slight hint of blue, and matches best with most LEDs. 8000K is our highest temperature, which produces an ice blue color. This is not a strong blue color though- it is still primarily white, meaning there will be no decrease in light output.
    Relay:
    Your Premium CAN-BUS HID Kit includes a brand new Heavy-Duty HID Relay, to power your HIDs directly from the battery, instead of the factory wiring. This relay has been designed from scratch, and utilizes a fully-sealed, waterproof relay, with flyback diode, and even has a built-in capacitor for input power smoothing. All wires are sleeved with braided techflex for an attractive appearance and extra protection. The input wires are each a meter long, and the output wires are one meter and two meters, which means the wiring will be long enough for even the biggest vehicles. The single-ground design makes installation easy. This relay was designed with reliability, convenience, and long-life in mind.
    Warranty: Our warranty is through Diode Dynamics, LLC, so you can be assured that you will get fast and friendly service should you have any problems. There is a full-replacement 1-year warranty on all HID Kit components, including HID Bulbs, Ballasts and Relay.
    Shipment: We carry our own inventory, so no waiting for them to be shipped from overseas, or waiting on big, unreliable suppliers to ship them. They ship right from our own inventory, in St. Louis, Missouri, usually the same day you order.
    Kit comes with:
    • One pair HID bulbs in your choice of bulb size and color
    • Two 35w super-slim ballasts
    • Mounting hardware for ballasts
    • Three-year limited warranty on all components
    • Free Diode Dynamics decal
    • Diode Dynamics 30-day satisfaction guarantee
    • Heavy-duty HID Relay Harness (Optional) to protect your factory electronics.
    High Beam HID Conversion Kit for 2004-2008 Pontiac Grand Prix
    Low Beam HID Conversion Kit for 2004-2008 Pontiac Grand Prix
    Fog Light HID Conversion Kit for 2004-2008 Pontiac Grand Prix
    1997-2003 Pontiac Grand Prix HI/LO Kit
    If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com
    *PM us for the free-shipping code* (U.S. forum members only)
    Thanks for looking!
    Nick C.
    Click For All Pontiac Lighting
    Your Experts in Pontiac Lighting
    (314) 205-3033
  1. Website to check out, including the MustRanger...this is bad..
    By Pittman06 in forum Off Topic Discussion
    Last Post: 12-12-2009, 11:03 PM
  2. questions on HID conversion kits
    By duffman87 in forum General Tech Discussion
    Last Post: 06-22-2009, 09:35 PM
  3. Some updated photos including true fire engine bay
    By VictorSmalls in forum Visual/Body Modifications
    Last Post: 04-30-2009, 07:13 AM
  4. HID Conversion Kits
    By DJFirestorm07 in forum Visual/Body Modifications
    Last Post: 11-25-2008, 12:40 PM
  5. E85 Conversion Kits
    By Quicklynx in forum General Tech Discussion
    Last Post: 09-05-2008, 03:29 PM
