Thread: Introducing DO line of outside mount nozzles.
Results 1 to 4 of 4
  1. #1 Introducing DO line of outside mount nozzles.
    DevilsOwn
    Guest
    Outside Mount Nozzles
    DevilsOwn is committed to providing you the best nozzle you can buy. DevilsOwn nozzles consistently deliver superior, long-lasting, trouble-free performance. Each nozzle is tested individually on flow rate, spray angle, balance, and uniformity of spray. You can't find a better nozzle anywhere. The DVL-2700 features 1/8' npt threads on the outside of the nozzle so that it can be screwed in from the outside of your intake. With built-in O-rings, leaks are something that are only associated with our competitors. The removable screw-in 80 micron filter allows for easy cleaning, and the nozzles are nickel-plated to protect from methanol and increase their life.
    The DVL-2700 nozzles disperse the alcohol/water mixture into the smallest droplets possible at any pressure above 40psi and produce a fog-like mist. They are small in size and weight and allow for maximum air flow into your intake without blocking it. DevilsOwn designed this nozzle unique with the orifice recessed, which when air passes over the nozzle a pressure drop is created on orifices. This dramatically improves atomization of the nozzle.
  2. #2 Re: Introducing DO line of outside mount nozzles.
    May 2008
    Winnipeg, MB
    whats this for?
    2007 Pontiac Grand Prix
  3. #3 Re: Introducing DO line of outside mount nozzles.
    TDCRacing
    Guest
    alcohol/water injection...Just a better type of nozzel used to spray the mixture into the intake.
  4. #4 Re: Introducing DO line of outside mount nozzles.
    Hoffman/Schaumburg, IL
    Pretty slick, It wouldn't be too hard to mount these into the manifold.....
  1. Engine mount idea
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 06-04-2008, 09:56 AM
  2. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
  3. 04+ fuel return line
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 11:40 PM
