Quote Originally Posted by Grandprix202 View Post
I know this doesn't really answer your question and it isn't meant to take away from your new ride... But did you buy it new? Becuase if you got it new there should be no swirl marks or scratches on it at all. If you got it new then you must have got a porter that had no idea what he was going. Reason why I'm saying this is because I'm a porter and they are so so strict about that stuff where I work.
This is a false statement. You would not believe what dealers do to new cars. New cars can have just as many defects as a used car. Defects being swirl, scratches and surface contaminants (rail dust, industrial fall out etc..). This is why on the detailing forums it's always recommended to have the dealer not wash or even detail the car on delivery. Same when someone takes a car to the dealer. It is recommended to have a few do not wash car signs to avoid the headaches.
Quote Originally Posted by spazzz View Post
Since you are doing it ALL by hand I would just clay, then get a good cleaner wax. That way you will really see what you are up against.
Honestly, getting set up to detail properly will cost a few $$. Start slow and build your arsenal.
A DA polisher,proper pads and backing plate, the 'right' kind of microfibers(so you don't destroy your work), compounds, polishes and your choice of sealant would be a start.
Meguiars line is definitely user friendly. Ultimate compound, ultimate polish and ultimate wax(the 3Us) will do a 180 on your car.
If you can catch a fingernail in a scratch, it won't buff out.
Time to browse Meguiars online and AutoGeek my friend.
I tend to agree with this. Investing in the proper equipment will definitely be the way to go. As stated, come over to Meguiar's Online and Autogeek. Your eyes will be opened on the proper way to do things. If you choose to go with a machine look at the Harbor Freight Dual Action Polisher. Get a better 5" backing plate and 5.5" pads and this machine does a good job.
Ahh alright. Then I take back what I said. Can't pass up a good bargain.
As a wax/sealer collinite 841 I belive it's called is good from what I've heard. I haven't used it on my car yet but I've used it on my wheels and it works great
Colinite has a following and is known for being durable. It's a good price but there are other products that can get the job done.
Quote Originally Posted by Adidasdude1989 View Post
So i just bought a 2014 Chevy Malibu 2LT. I just got it last week and i noticed theres minor scratches, swirl marks and haze. Im new to detailing so im kind of confused on the steps and maybe what products i should get. I was looking more into Meguair's products to start off with but im willing to take recommendations from everyone here.
Anyway, what steps should i do? Of course washing 1st is obvious. Should i use the clay bar next? What step does the polishing compound come in? When do i wax the car? Im just kind of lost, im new to this so i apologize. Also, what can i use to keep the plastic on my head light and tail lights clean and protected? Can i use something in between washes to keep the plastic clean if they got dirty?
Again my apologies for all the questions. I have a real nice car sitting outside and i need to learn the proper car for it. I wanna add that everything will be done by hand.
First off congrats on the new car. What color did you get? That doesn't matter as the process is the same but it takes a little more effort on a dark colored car.
You can only do so much by hand. You won't remove all the swirls and scratches but you can make the car look better. This is a good thread on doing things by hand or machine.
http://www.autogeekonline.net/forum/...s-machine.html
I would recommend you pick up a set of these pads when doing things by hand. They will give you more correction power than a typical foam applicator. I use them on areas that I can not get a DA.
http://www.autopia-carcare.com/hydro...pplicator.html
Now that we have that out of the way this is what I would recommend you do a test spot with the least aggressive method. Start with a polish. If you need more correction then go to the compound. But the typical steps are the following:
1. Wash
2. Clay - Removes bonded surface contaminants from the paint.
3. Compound - Removes swirls and scratches
4. Polish - Gives the paint gloss and refines the finish from a compound. If you are happy with the finish after compounding then continue to waxing
5. Wax or sealant or both
6. Maintain - using a spray wax in between washes will extend the life of your protection but also add some shine and protection.
Meguiar's offers great products. The ultimate line is great and a good place to learn. They will keep the car looking good and protect it. I always recommend this kit to new folks on the Meguiar's forum when starting out. It has everything you need. You can only get it online.
http://www.walmart.com/ip/Meguiar-s-...undle/29670206
I would also recommend you pick up some good quality microfibers. You can never have enough microfibers. These are good for the price
http://www.walmart.com/ip/Meguiar-s-...ingMethod=p13n
Don't forget a drying towel or 2. These are good. The Rag Company is having a 20% off sale for this weekend. Use PS20
http://www.theragcompany.com/Dry-Me-...09-2659-OW.htm
I am really liking the plush towel lately. It's a large towel and very soft.
http://www.theragcompany.com/The-Edg...-2040-EL-W.htm
In regards to keeping your headlights clean and protected. You have a couple options. You can either use ultimate compound and ultimate wax from the provided kit or you can invest in Meguiar's Plastx and Meguiar's Headlight Protectant. Headlight protectant is a little more durable than ultimate wax on headlights. You will have to apply it more often. The general recommendation is every 6-8 weeks or when the water is not beading or sheeting off the lenses. For the tails just use ultimate wax. They don't tend to oxidize like headlights.
Just so you know there are a couple different references to protection. You have carnauba wax and sealants (aka synthetic waxes). The difference being that sealants last longer, typically 4-6 months. Carnauba's offer that warm look and typically last 1-3 months. There are those that apply a sealant first followed by a coat of wax to get the best of both worlds. You get the protection of a sealant and the look of a carnauba.
I mentioned in those steps a maintenance step. What I mean by this is that after you wash your car hit it with a spray wax. It will add shine and protection. But it will also boost the existing wax or sealant on the car.
I almost forgot about the wheels and tires. Meguiar's All Wheel & Tire Cleaner works on both wheels and tires. Use it clean your tires and then apply a tire dressing. A few of my favorites Meguiar's D163 Tire & Trim Gel, Meguiar's Ultimate Black Tire Coating (lasts longer than a tire gel), Turtle Wax Jet Black Endura Shine Tire Coating (lasts very long in terms of months). Are the wheels OEM?
These are a couple more threads that are useful. Don't hesitate to ask any more questions. I invite you over to Meguiar's Online if you go the Meguiar's route.
http://www.meguiarsonline.com/forums...Series-Claying
http://www.meguiarsonline.com/forums...Series-Washing
http://www.meguiarsonline.com/forums...my-paint!-quot
