Thread: *cleaned* Cleaning my carpet out of the car
Results 1 to 20 of 27
  1. #1 *cleaned* Cleaning my carpet out of the car
    Ocala, FL
    I have my carpet out of the car. Should I go through a different process than just using something like folex to spot clean stains? Hose it down? My only concern with hosing it is getting water trapped inside and causing mold.
    Here's a couple pics:
  2. #2 Re: Cleaning my carpet out of the car
    Yoga city
    i steam cleaned mine with the rug scubber from my house, made old 97 carpet look new. you could benefit greatly
  3. #3 Re: Cleaning my carpet out of the car
    Texas
    God I really need to get off my ass and do this to my 97. Subscribing for when I do mine.
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: Cleaning my carpet out of the car
    Waukesha, WI
    i took my old one to a quarter car wash and used the tire cleaner with a scrub brush, then preasure washer
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  5. #5 Re: Cleaning my carpet out of the car
    Yoga city
    telling you a good rug scrubber will do the job
  6. #6 Re: Cleaning my carpet out of the car
    after my car got flooded, i took out the carpet, it took a week to dry hanging, the foam will hold a lot of water.
    after it hung for a few days i started dumping baking soda all over it. (kills the smell from being flooded) when it was bone dry i used a bissil home rug shampooer, i had to use the hand held attachment for the most part, but it really made a difference. the steam cleaners you can rent from the supermarket will also do a great job.
    SE Level Member thenose's Avatar
    Apr 2012
    Athol, Massachusetts
    I found a Bissel deep cleaner at a yard sale. Bought it for $10 and it did a great job on the carpet. And I can use it to clean up after the CAT!
  8. #8 Re: Cleaning my carpet out of the car
    May 2012
    i would just replace it i did mine for about 200 because my carpet was so far gone
  9. #9 Re: Cleaning my carpet out of the car
    Florida
    The way i've always done mine is to use a big ass bucket/tub, and fill it full of water, and a cleaner of your choice (I use a whole bottle of simple green) and let it soak for a few hours. Then take it out, and pressure wash it clean. Then, let it sit out in the driveway, moving it every 10-20minutes so that isn't sitting in a puddle. After doing that a few times, she's dry, and looks new
  10. #10 Re: Cleaning my carpet out of the car
    Minnesota
    If you go on Rockauto.com you can actually get new carpet in OEM colors that is molded. It also gives the option of having "Mass black" sound deadening added to the carpet for sound deadening.
    I am going to be doing this after this Winter.
  11. #11 Re: Cleaning my carpet out of the car
    Ocala, FL
    Quote Originally Posted by Pure2sin View Post
    I've installed new carpet in a gp.. It turned out pretty good, just not quite perfect.
    I want to try and clean the carpet up in this one though, it's not my dd so not looking to dump money into it.
    the carpet in my dd is clean, .
    Ill post pics once I've got it cleaned up.
    Thanks for all the input guys.
  12. #12 Re: Cleaning my carpet out of the car
    Minnesota
    You have any pictures of the Rockauto carpet? What made it not quite perfect?
  13. #13 Re: Cleaning my carpet out of the car
    i looked it up for a regal, and it looks like it lays over the old carpet, no foam is mentioned at all. just some black matt stuff.
  14. #14 Re: Cleaning my carpet out of the car
    Texas
    85 Corvette
    01 TA
    03 Z06
  15. #15 Re: Cleaning my carpet out of the car
    Minnesota
    Quote Originally Posted by txslow6 View Post
    I think that is the same stuff as on Rockauto:
  16. #16 Re: Cleaning my carpet out of the car
    Ocala, FL
    Carpet is cleaned up now, here's a few more pics of how bad it was:
    When I replaced carpet, I didn't use the stuff from Rockauto.. I did some research and found people thought the carpet from accmats.com was the best, so that's what I went with.
    It's important to spend a lot of time making it right, or it won't turn out good. You have to cut holes in the molded carpet, so it helps if you have the stock carpet to use as a reference.
    I actually cut out the pans and some other areas to bulk up the replacement carpet, as it just wasn't thick enough in a few places, even with the extra mass backing. I used glue to ensure a good fit almost everywhere. Even spending all this time, I still ended up with a few areas where it just wouldn't lay completely perfect, nothing to really complain about though.
  17. #17 Re: Cleaning my carpet out of the car
    Ocala, FL
    Here it is all cleaned up!
  18. #18 Re: Cleaning my carpet out of the car
    Apr 2012
    Wow. Nice job.
  19. #19 Re: Cleaning my carpet out of the car
    Jun 2013
    Canada
    Quote Originally Posted by codyAK View Post
    What did you do/use to clean it? Also how do you put the carpet back in, do you have to do any gluing or just put it back in then put everything else back over top of it?
  20. #20 Re: *cleaned* Cleaning my carpet out of the car
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Looks clean boss.
  1. Need new Carpet?
    By Spartan GL in forum Visual/Body Modifications
    Last Post: 05-21-2010, 01:14 AM
  2. Interior cleaning tips? Wet carpet is finally dry.
    By Tfreeds in forum General Tech Discussion
    Last Post: 02-19-2010, 07:42 AM
  3. carpet
    By 05gpgt in forum Detailing Tips and Tricks
    Last Post: 11-20-2009, 06:32 PM
  4. New Carpet...
    By drunknmunky in forum Visual/Body Modifications
    Last Post: 04-24-2008, 03:13 PM
