Thread: This is what I got to start with.
Results 1 to 17 of 17
  1. #1 This is what I got to start with.
    GTP Level Member
    Sep 2011
    Motown
    Srry about the image size but anyway this is what I got. Ya I know its dirty thats why this is on here. What I want to know is how am I going to attack this project of cleaning this dirty engine bay. What would I need to do in order to make it look brand new?
    [IMG][/IMG]
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  2. #2 Re: This is what I got to start with.
    you can use foaming tire cleaner and spray it all over and wipe it down.
  3. #3 Re: This is what I got to start with.
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Napalm.
    The evil LG8 still refuses to die.
  4. #4 Re: This is what I got to start with.
    Just kidding, tire cleaner seems to be the best. Since that's obviously clay, soak it (try) for a few hours leading up to it. Spray it with tire foam and go to town with a nylon bristle brush.
    Then degreaser it, and reapply tire foam.
  5. #5 Re: This is what I got to start with.
    Charles City, IA
    degreaser, water, brush, and time.
    SMGPFC Two Nipple General
  6. #6 Re: This is what I got to start with.
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
  7. #7 Re: This is what I got to start with.
    Out West
    gasoline.
    Whine with your Cheese?
  8. #8 Re: This is what I got to start with.
    GTP Level Member
    Sep 2011
    Motown
    Quote Originally Posted by csssaint12 View Post
    Did you take anything apart to clean it or leave it all in one piece and clean around it? If you get what i am trying to say.
  9. #9 Re: This is what I got to start with.
    Nov 2009
    Quote Originally Posted by Classy Pontiac View Post
    Just cleaned around everything. Didn't see the need to disconnect or take anything out because living in MN = automatic dirty engine bay so I just have to do it every summer.
  10. #10 Re: This is what I got to start with.
    GTP Level Member
    Sep 2011
    Motown
    Ok thanks for the tip
  11. #11 Re: This is what I got to start with.
    SE Level Member McCoyH's Avatar
    Mar 2012
    Iowa
    2 cans of Engine Degreaser ($4 at walmart, blue can)
    Pressure washer or car wash (make sure your motor isnt hot, and dont spray electrical components
    Meguires dash shiner ($4 at walmart)
    Blue shop towels
    spray motor with the degreaser, let sit for a minute or two, spray it off, let it dry, use meguires (prolly spelled that wrong) on all black plastic pieces and trim wipe on and off with shop towels.
    Thats what I do, I detail at a car lot.
  12. #12 Re: This is what I got to start with.
    Jan 2012
    Philadelphia
    all engines have so many electrical components now its retarded.. What electrical componets would you recomend to cover up cause i know for sure theres no way your gonna avoid every one
  13. #13 Re: This is what I got to start with.
    Mar 2012
    Iowa
    Ha, I know. Honestly I've never really had any problems just spraying the whole thing down. Basically I just avoid staying on the plugs, fuse box and other main electrical components for very long while spraying.... The only "problem" I've ever had was when I was spraying an older car with a GM 350 some water got in the spark plug boot or something and it idled like poop for about 2 mins then was fine. Idk, just be carefull and don't soak anything electrical...
  14. #14 Re: This is what I got to start with.
    with the stock air box on, i hosed the entire engine, everything and everywhere. have done it 3 times to this car, and both of my last 2 trucks. dont use a real power washer, it can rip wires apart.
    de grease, and hose it down with a full force garden hose with a spray nozzle.
    after the first go around, if you see any greasy areas, re spray and hit it with a stiff paint brush or what ever you got to scrub with that will fit where you need it to.
    if you have a compressor, blowing all the water of everything is nice, but not needed.
  15. #15 Re: This is what I got to start with.
    Mar 2012
    Iowa
    Yeah forgot to mention, hold the pressure washer gun a few feet away, so you get an indirect, but still somewhat powerful blast of water that won't rip things apart. Obviously don't put it 3 inches away or youll destroy things, lol.
  16. #16 Re: This is what I got to start with.
    true that, and a tad bit of common sense goes a long way too.
  17. #17 Re: This is what I got to start with.
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    If someone is stupid enough to spray a power washer on there engine from half a foot away then they really shouldn't be working on or cleaning there car! It takes paint off of walls etc my mom who knows squat about cars or cleaning them wouldn't even be that dumb
  1. Won't start! Please help!
    By fpgt17 in forum Off Topic Discussion
    Last Post: 01-22-2011, 12:10 AM
  2. Car Won't Start!!!!!!!!!!
    By mminchau in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 02:21 PM
  3. Car Won't Start
    By mminchau in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2010, 05:36 PM
  4. HELP Will not start
    By chuckd98gtp in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2009, 01:23 AM
  5. Where should I start on my 07 gt?
    By 07gpgt in forum General Tech Discussion
    Last Post: 04-30-2009, 03:15 AM
