Thread: How To Detail Engine Bay
Results 21 to 40 of 41
  1. #21 Re: How To Detail Engine Bay
    Bunnell, FL
    you can hit it w/ black spray paint too. the hood liners love to soak up the paint
    but i ripped mine out a few months ago
    I'm a Sex Offender
  2. #22 Re: How To Detail Engine Bay
    SE Level Member Cobraeater's Avatar
    Ohio
    Anyone want tips from a professional detailer? I have detailed 1000's of cars and never used garbage bags lol or a paint brush to much work. If you want fast and easy the best stuff is purple power from Walmart or where ever its like 3 bucks for a gallon anyway spray wd40 on electrical parts then soak engine bay with purple power then wait start your engine and simply pressure wash grease off if need be do it a second time wait till dry then shine I use ardex details it's an aerosol detail spray any questions about anything pm me
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    I washed the car yesterday and opened the hood to find a white stained hood liner. I just used the hose and rinsed the liner and the entire engine bay. I left the hood open with the car in the garage over night. Liner was dry and white stains gone this morning! I have a spot where the belt is throwing crap from a leak that'll need some thing a little stronger. I need to degrease the engine so I can find the source of the leak.
    Sent from my DROID RAZR using Tapatalk
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  4. #24 Re: How To Detail Engine Bay
    Snout seal most likely.
    Or something is on the belt getting tossed up there, ala...axle grease?
    To add...hood liner, throw it out...
    Toledo, Ohio
    Can't be snout seal.....as I am just a slow GT....lol.
    Yeah, something is getting on the belt and is getting thrown everywhere. It does have a slight green tint to it so i was thinking LIM gasket or coolant elbows....stuff is on the firewall....coolant overflow tank. Even saw it down below when I was changing out my tie rid ends and wheel bearings. It's kind of thick though....like a gummy residue. I did the LIM gasket on my 00 GT a few years ago and made the mistake of not thoroughly cleaning the engine bay first. It would've made the job cleaner and easier.
  6. #26 Re: How To Detail Engine Bay
    Gummy, green residue...I'm still betting axle grease.
    Toledo, Ohio
    I hope you are right. Over greased axle? I don't have any visible leaks anywhere but the engine is definitely much dirtier in the area around the coolant elbows.
    Heres a pic:
  8. #28 Re: How To Detail Engine Bay
    Toledo, Ohio
    After doing some reading, looks like i'm replacing an axle. This was on the same side as my bad wheel bearing.
  9. #29 Re: How To Detail Engine Bay
    yup axle boot and thats not bad at all so your lucky
    SMGPFC Member #10
  10. #30 Re: How To Detail Engine Bay
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    I suggest removing both belts before you wash the engine bay and wipe down the pulleys and idlers with brake cleaner before reinstalling. Just to avoid getting anything on the belts or pulleys that might cause squeaks
  11. #31 Re: How To Detail Engine Bay
    Dec 2010
    Ohio
    This stuff etches engine enamel BTW just an FYI if you have anything painted under the hood
    Derp RALM's Avatar
    Aug 2012
    Brandon, South Dakota
    What would be the best way to wash everything down without a hose? If you're like me and live in an apartment you don't really have access to a hose. I suppose I could use a glass of water?
    1995 Grand Prix SE 3.1L V6 N/A
    216,000 Miles
    1998 Grand Prix GT 3.8L V6 N/A 211,000 Miles (RIP)
  13. #33 Re: How To Detail Engine Bay
    Quote Originally Posted by RALM View Post
    best bet is a coin op car wash, the kind with the power sprayer. self serve deal. ive de-greased more then one cars engine and bay at one of those places.
    Derp RALM's Avatar
    Aug 2012
    Yea I was thinking either that or bucket of hot water. I figured since my 95 isn't moving right now I'd detail engine bay plus the 98 is REALLY bad because it was driven on gravel for most of its life
    216,000 Miles
  15. #35 Re: How To Detail Engine Bay
    GT Level Member Jtiger360's Avatar
    Nov 2012
    United States
    I'm a noob, what sensors and where are they that I have to cover before I start cleaning?
  16. #36 Re: How To Detail Engine Bay
    Just use common sense...don't spray alt, or directly on exposed wires/plugs.
    The end.
  17. #37 Re: How To Detail Engine Bay
    Nov 2012
    United States
    Quote Originally Posted by blueguy91 View Post
    The end.
    I think I read somewhere I got to cover the fuse box as well and few other things..but what you said makes scents...I just get paranoid.
  18. #38 Re: How To Detail Engine Bay
    I never covered the fuse box.
    It's good enough as is.
    I live here. DirtDog's Avatar
    Jun 2012
    The end.
    As a side note I have cleaned several engines for people and spray mine off once a month to keep it show ready lol. The only thing I cover is my open cone intake and I've never covered the alternator. I usually disconnect the battery but that's a personal choice. Then I'll wipe off spots I don't want winter spots on then hook battery back up and drive along about my day
    Sent from my DROID RAZR using Tapatalk 2
  20. #40 Re: How To Detail Engine Bay
    Nov 2012
    United States
    Quote Originally Posted by marines542 View Post
    You disconnect both terminal or just the negative one? Your way sounds 10x easier!
  1. Some new mods + a major detail, claybarred etc.
    By boostedzx3 in forum Visual/Body Modifications
    Last Post: 05-27-2010, 09:28 PM
  2. Engine Detail/Paint
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 09-14-2008, 11:00 AM
  3. Engine bay detail parts questions...
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 07-12-2008, 11:26 PM
  4. fresh detail pics
    By UR LOSN in forum Visual/Body Modifications
    Last Post: 05-22-2008, 11:27 AM
  5. Suggestion: Detail thread?
    By GP2003GT in forum Forum Bugs/Suggestions
    Last Post: 03-13-2008, 07:57 PM
