Thread: Strongest OTC glass cleaner?
Results 1 to 20 of 26
  1. #1 Strongest OTC glass cleaner?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Im trying to clean the windows on the GTP and they are nasty, invisible glass got the surface stuff off but that's it, tried a claybar, no luck.
    The driver side window also has paper stuck to it from window stickers, I cant get off.
    Whats the strongest/ best stuff I can use to remove the grime, waterspots and stickers?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Strongest OTC glass cleaner?
    Feb 2013
    37.295091, -121.930053
    believe it or not try some tooth paste and some 0000 steal wool in soapy water
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Strongest OTC glass cleaner?
    GXP Level Member
    Mar 2015
    Tomball
    Stickers? Try WD-40
    Jeff
  4. #4 Re: Strongest OTC glass cleaner?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    Take a razor blade holding it at an angle and use any type of glass cleaner as lube and clean your windows with it. Watch this video as well:
    https://www.youtube.com/watch?v=q4WwOrkgXlc
  5. #5 Re: Strongest OTC glass cleaner?
    Jul 2010
    Coquitlam,BC,Canada
    Brake-kleen. I use that sh!t on everything! LOL
    Ad a razor blade to the mix and you should have clean glass in no time.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Strongest OTC glass cleaner?
    Jan 2014
    AR
    Paint prep degreaser, solvent based. Such as PPG's DX330. 3M's general purpose adhesive remover is a bit milder and is commonly sold OTC in quarts. Follow with Sprayway glass cleaner and wads of newspaper. Mild paint polishes or cleaner / wax type products don't seem to hurt glass, just don't try gritty rubbing compound. As mentioned, good quality 0000 steel wool is safe if used gently and lubed with glass cleaner. None of this would really be safe to try on film tint.
  7. #7 Re: Strongest OTC glass cleaner?
    Sep 2014
    Worcester, MA
    Adhesive remover.
  8. #8 Re: Strongest OTC glass cleaner?
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by hockeybawler View Post
    One of the best videos to watch on prepping glass.
  9. #9 Re: Strongest OTC glass cleaner?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I've always had the best luck with Goo Gone and a razor blade. I let the Goo soak for about 10 minutes, then the sticker generally scrapes right off. Then Invisible Glass does a great job of cleaning the remaining goo off.
    Just remember, if you have to do the inside of your rear windshield, be very careful about the rear defogger.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  10. #10 Re: Strongest OTC glass cleaner?
    Jan 2014
    AR
    It probably goes without saying but... if using a razor blade, always start with a freshly unwrapped brand new and clean blade. Plastic razor blades are also available.
  11. #11 Re: Strongest OTC glass cleaner?
    Oct 2011
    huntley
    Quote Originally Posted by The Guz View Post
    I agree, very expensive products from him but the man knows his stuff and is very informative. Personally I am a fan of Adams Polishes. Seems to work well for myself.
  12. #12 Re: Strongest OTC glass cleaner?
    Sep 2014
    Richmond Virginia
    The razor blade isn't going to ruin the factory tint?
  13. #13 Re: Strongest OTC glass cleaner?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Quote Originally Posted by 04lss View Post
    Are you trying to clean the inside or outside of the windows? If you have tint and are trying to clean the inside of the windows, you need to ignore everything said above.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  14. #14 Re: Strongest OTC glass cleaner?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by LeadfootCJ7 View Post
    For sure. I thought he got a no parking here sticker or something like that.
  15. #15 Re: Strongest OTC glass cleaner?
    Jul 2010
    Coquitlam,BC,Canada
    It will speed up the tint removal process. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #16 Re: Strongest OTC glass cleaner?
    Sep 2014
    Richmond Virginia
    outside, and im not sure what kind of sticker it was theres just little pieces of paper stuck to window, that haven't been coming off.
  17. #17 Re: Strongest OTC glass cleaner?
    Dec 2008
    Lawndale, CA
    If you don't have tint on the outside the technique in the video will work just fine. 3M adhesive remover or goo gone will help loosen the adhesive. A heat gun also helps.
    Glass cleaner alone will not remove it.
  18. #18 Re: Strongest OTC glass cleaner?
    Sep 2014
    Richmond Virginia
    in addition to the sticker residue, there are a crap load of waterspots
  19. #19 Re: Strongest OTC glass cleaner?
    GXP Level Member
    Mar 2015
    Tomball
    I've always used WD-40 and it works great on adhesive, plus almost everyone has it just sitting on the shelf.
  20. #20 Re: Strongest OTC glass cleaner?
    Jul 2010
    Coquitlam,BC,Canada
    Try the razor blade in a small area. You'd be amazed at how much crap is on the glass, and the razor gets rid of it. I do it all the time, and use glass cleaner to keep things wet.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. INFORMATION Review - Glass Cleaners, Glass Sealants, Glass Coatings
    By The Guz in forum Detailing Tips and Tricks
    Last Post: 09-04-2015, 01:51 AM
  2. INFORMATION Cleaner Wax Review
    Last Post: 08-03-2015, 08:27 PM
  3. Better Glass Cleaner?
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 05-19-2012, 08:48 AM
  4. Is there a cleaner way to do this? (ghetto rig)
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-10-2011, 12:08 AM
  5. Hand Cleaner
    By tdm571 in forum Off Topic Discussion
    Last Post: 03-10-2011, 10:31 AM
