Thread: Best way to clean a $400 car
Results 1 to 20 of 22
  1. #1 Best way to clean a $400 car
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I just bought a 2002 GTP 4door paid 450 out the door. needs some mechanical work, but overall the car is in good shape. The interior is pretty good for a 200k GM, but it is filthy with caked on dirt.
    I broke out my meguiars Cleaning spray, and my detailing sprays, but they don't seem to cut it in certain areas. How do I really clean this thing so that I wouldn't be afraid t eat after touching something inside of it. The dash, seats and carpet are my biggest areas. Any products of techniques I should try?
  2. #2 Re: Best way to clean a $400 car
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    pull the seats, pull the carpet, find a car wash.
  3. #3 Re: Best way to clean a $400 car
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    rent a steam cleaner
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  4. #4 Re: Best way to clean a $400 car
    Dec 2008
    Lawndale, CA
    Leather or cloth interior?
  5. #5 Re: Best way to clean a $400 car
    i use tuff stuff interior cleaner, stuff great. its good for seats, rugs, door panels, dash and all plastics. ive sprayed it all over lol
  6. #6 Re: Best way to clean a $400 car
    Feb 2013
    37.295091, -121.930053
    your going to need soapy water and a back bone to clean it right or........ you could replace it all from a donor car
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  7. #7 Re: Best way to clean a $400 car
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by The Guz View Post
    Leather
  8. #8 Re: Best way to clean a $400 car
    Sep 2014
    Richmond Virginia
    if I got a donor car then id be back to square one
  9. #9 Re: Best way to clean a $400 car
    GT Level Member MyLittlePony's Avatar
    Mar 2015
    Franklin, TN
    Any pics of said car?
  10. #10 Re: Best way to clean a $400 car
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by LS1Adam84 View Post
    im in class tonight, and work/class all day tomorrow. I should have some on Thursday.
  11. #11 Re: Best way to clean a $400 car
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by ScottyDoggs View Post
    Ill give it a shot worst case ill pull the carpet out and power wash it.
  12. #12 Re: Best way to clean a $400 car
    Feb 2013
    your going to need leather oils
  13. #13 Re: Best way to clean a $400 car
    Sep 2014
    Richmond Virginia
    So the seats ARE leather? I thought they were plastic leather?
  14. #14 Re: Best way to clean a $400 car
    Feb 2013
    more like vinyl or really cheap leather but either way the leather oils works on both so i on that.
  15. #15 Re: Best way to clean a $400 car
    Dec 2008
    Lawndale, CA
    The leather is really easy to clean. The leather in the car has a coating on it. That coating protects the leather. It's not like uncoated leather which becomes dry and needs to be rejuvenated with oils. So with coated leather you are cleaning the actual coating and not the actual leather. If the coating has failed, one will see color transfer on the applicator.
    I pulled this from a thread on Autopia car care.
    Caring for pigmented leather is truly about keeping the leather clean. Dirt and particulate will scratch and wear the leather leading to shiny appearance and exposure of the leather hide underneath. Acidic body oils can wear or stain the vacuum frequently and use a gentle, water based cleaner to remove embedded dirt and oil. Use a protectant or conditioner that features protectants (to reduce abrasion and increase sun fade resistance). Over time the leather coating will crack microscopically or stretch in the seams and folds. Conditioners can penetrate the coating through these cracks and openings, keeping the leather underneath soft and supple.
    This is a good reference video
    In regards to products, some All Purpose Cleaner would work on all surfaces. I would recommend something like Meguiar's D101 with the spray bottle mixed at 10:1. It can be used on most surfaces. I have used it on leather and the plastic interior pieces with no issues. It can be used on upholstery as well. I would recommend getting a brush to scrub the leather seats to pull out a lot of the dirt. I have used APC on leather but it can sometimes leave the leather feeling a little sticky. So following up with a damp microfiber towel can help with that. I personally follow up with a leather conditioner to add a barrier between the seat and the person. I use APC for deep cleanings.
    If you are looking to pick up some products locally, Meguiar's Gold Class Leather & Vinyl Cleaner and Meguiar's Gold Class Leather Conditioner work very well. These are strictly leather products.
    Meguiar's Quick Interior Detailer has a light cleaner built in that can be used on all surfaces. I use a lot of this and would recommend it. For a heavily soiled interior, APC is the way to go.
    Here are a couple reviews of some leather cleaner and conditioners that I have done.
    These Blackfire products are great and would recommend them as well.
    http://www.autopia.org/forums/detail...nditioner.html
    These Meguiar's products are only available in gallon sizes.
    http://www.autopia.org/forums/detail...r-cleaner.html
  16. #16 Re: Best way to clean a $400 car
    Sep 2014
    Richmond Virginia
    Thaks for the info, im going to try an APC, then go over the seats with meguiars leather cleaner/conditioner, and the dash/doors with meguiars protectant.
    Not sure what im doing with the floors yet.
  17. #17 Re: Best way to clean a $400 car
    Jan 2014
    AR
    Heck I thought it was dog leather, now I know better! When I don't know just how nasty something is, I like to start with warm water and a sponge with plenty of clean towels to dry off. Same on carpet but add in a shop vac. I don't like carpet pads to ever get wet, they take too long to dry. So I sponge on some water (to already well vaccumed carpet) then wipe carpet with dry towel and vaccum. Keep repeating until water isn't helping then switch to TuffStuff for the finish. I've gotten lots of coffee stains out this way, but nothing would beat a good steam clean for carpet. Whether the french fry that just fell on the floor is safe to consume after all that... is anybody's guess!
  18. #18 Re: Best way to clean a $400 car
    i like that pc brush in the vid.
    tuff stuff has always done well by me. bucket or warm water, spray it on let it sit a minute to soak in, then use a scrub brush like in the vid if need be, wipe off with a dry rag, then with a damp rag with the warm water wipe it all down. 2 bucket system works well for this, one to rinse, one to get more clean water on the rag.
    tuff stuff has even removed tar from the inside door panels. i always got a can on hand lol
  19. #19 Re: Best way to clean a $400 car
    Jan 2014
    AR
    Aw yea I forgot brushing, its a nutritious part of a complete cleaning. I use a tire or vegetable brush on carpets.
  20. #20 Re: Best way to clean a $400 car
    Jan 2014
    AR
    Another bonus tip, sorry: On occasions where a mechanic had stepped in grease and got it on carpet, and I was the post-service detailer, I discovered that paint prep solvent (wax and grease remover) if used sparingly can actually wipe those spots off if caught before its ground into the rug. Never had it discolor the carpet. Using solvent is kinda like what they call dry cleaning for clothes.
  1. Clean up
    By Dthreap in forum Buy/Sell Other/Misc
    Last Post: 07-02-2012, 04:40 PM
  2. Need to clean my reservoir
    By DRWBRTq19 in forum General Tech Discussion
    Last Post: 08-15-2011, 06:07 PM
  3. Clean a Supercharger?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 09-27-2009, 10:02 PM
