Thread: lowering my 04 impala ss
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 lowering my 04 impala ss
    GXP Level Member ryangtp89's Avatar
    Maine
    I was thinking about lowering my impala and putting 18's on. I was looking at the SSC springs how are they ? Will I need shorter dog bones to eliminate vibration ?
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 lowering my 04 impala ss
    Quote Originally Posted by ryangtp89 View Post
    You can but a better option is Vinnie spacers
    Vinnie spacers > shorter dogbones
    http://www.grandprixforums.net/showt...?t=1107&page=5
    04 Comp G.
  3. #3 Re: lowering my 04 impala ss
    I run ssc's, no problems with them. They are on kyb struts.
    And yeah get motor/trans mount spacers, shorter dog bones are dumb.
  4. #4 Re: lowering my 04 impala ss
    Maine
    is there any other retail stores that sell the motor mount spacers ? I don't use paypal.
  5. #5 Re: lowering my 04 impala ss
    Jul 2010
    Coquitlam,BC,Canada
    .....motor mount spacers.....
    I took measurements when I made mine.....
    http://chrisb.users.superford.org/Gr.../Lowering.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: lowering my 04 impala ss
    Maine
    Ok i'll look into the kyb struts, do you know which ones I would need ? and i'll check out the Vinnie spacers.
  7. #7 Re: lowering my 04 impala ss
    take a 3/8" piece of steel plate and cut rectagles out of it the same "size" as the motor mounts, then drill holes for the studs. it's that easy.
  8. #8 Re: lowering my 04 impala ss
    Maine
    I don't want too lol, I'd just rather buy it pre made.
  9. #9 Re: lowering my 04 impala ss
    Maine
    What springs did you use ? And with that parts list you didn't get any vibration at wot ?
  10. #10 Re: lowering my 04 impala ss
    Jul 2010
    Coquitlam,BC,Canada
    SSC.
    Not at WOT. I have slight vibration at higher speeds, which I will solve with taller spacers.
    I am am currently suffering from what I believe is a bad CV OR two, so that problem needs to get fixed first.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: lowering my 04 impala ss
    Maine
    Are you going to make those ? The vibration can't be too bad without the spacers.
  12. #12 Re: lowering my 04 impala ss
    Nov 2012
    Madison
    Some people need them and most people need them.
    I thought I would win the spacer free SSC lottery, but not a chance.
    I ended up PMing Vinnie and ordered up a set.
    Try it without, see if you need them and find out what the wobble is all about.
  13. #13 Re: lowering my 04 impala ss
    Jul 2010
    Coquitlam,BC,Canada
    Yes.
    Not bad, but so annoying.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: lowering my 04 impala ss
    Under normal driving and normal throttle I never felt vibrations. The second I tried to go full throttle and over 50 mph it would shake alot and keep getting worse until you let off the gas. After installing the spacers it all went away. Having correct axle geometry is key, not only for vibrations sake but for keeping the axle straight so they don't beat themselves apart.
  15. #15 Re: lowering my 04 impala ss
    Maine
    I didn't know he still made them. What's his username ? I don't wanna take any chances. The SSC springs should look good with the 18" foose wheels I'm getting
  16. #16 Re: lowering my 04 impala ss
    Nov 2012
    Madison
  17. #17 Re: lowering my 04 impala ss
    Maine
    still no response from vinni
  18. #18 Re: lowering my 04 impala ss
    Never Never Land
    Fresh axles and mount spacers should avoid any axle vibration. I have a full stack of Vinnie spacers and I get axle vibration. But my car is lower than the majority. And I also have stock 146K axles. I think if I replaced axles i'd be okay and it'd go away.
  19. #19 Re: lowering my 04 impala ss
    Maine
    would it be a pita to install the spacers if I already have the lowering kit installed ?
  20. #20 Re: lowering my 04 impala ss
    Nov 2012
    Madison
    NOPE same way either way.
    I did mine after the trial period.
    Vinnie ever get back to you?
