Thread: Vogtlands vs Eibach
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 105
  1. #41 Re: Vogtlands vs Eibach
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by GTpEazy View Post
    I didn't mean in the GP world Lol, I'm still new to this stuff I meant in civics and such they run staggered stance does a square stance give more overall grip?
    Staggering is for traction, so on a FWD car, the wider rubber would go on the front. Great for the track, stupid on the street.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #42 Re: Vogtlands vs Eibach
    Aug 2015
    Earth
    EDIT: Dezebe also runs 37 mm front RAT bar, I'm not 100% if he has the addco bar but let's say he does... so wouldn't the balance of 37/22 be similar to the GMPP's 34(33?)/19 except the GMPP setup being less stiff due to less wheel rate but also having more grip since it's slightly softer? He runs star specs which are pretty much the best tires you can get that's street legal and 200 tw rating (the Ecsta XS I want is almost as good but I think the star specs got stiffer sidewall)... also have you thought about running WBS's rear lowering springs? They lower 1" exact and their spring rate is 230# compared to vogtland's 140#, I think the absolute perfect balance and perfect rotation might be with the 230# springs and 19 mm bar but again I'm noob and most people here know better
  3. #43 Re: Vogtlands vs Eibach
    Aug 2015
    Earth
    Yeah I changed my mind on that since someone pointed out the tire rotation goes out the window... so a square stance is probably best on the street where you have to worry about tire wear
  4. #44 Re: Vogtlands vs Eibach
    Go all out!
    Dorman front, Addco rear, Billstein coilovers, bmr or HT ta/lateral arms. I'm sure it'll handle well for a boat
    04 Comp G.
  5. #45 Vogtlands vs Eibach
    And better order a Addco while you still can. Yea there's a wait but the longer and longer you wait the less likely that you'll find it offered anymore.
    04 Comp G.
  6. #46 Re: Vogtlands vs Eibach
    Aug 2015
    Earth
    Think more positive man, our gp weighs 3500 lbs right? How much does the new Z06 weigh? 3500 lbs.... so our GP = C7 Z06 😂😂
  7. #47 Re: Vogtlands vs Eibach
    Aug 2015
    Earth
    Def will get an addco no doubt but since gmpp is available in junkyards for cheap might as well get one of those too
  8. #48 Re: Vogtlands vs Eibach
    I ran Potenza RE960PP 245/45/18 for summer. I'm in CT/MA so I hear you on the rust issue. I do not believe GMPP are solid, however in 5 years and 100K I did not have a problem with rust.. actually I ripped a sway bar perch off a control arm and had to weld it back on. Likely that was a poor weld.
  9. #49 Re: Vogtlands vs Eibach
    Aug 2015
    Earth
    Potenzas😱? Fancyyyy, take it out on road courses once in a while and see what the car can do and watch the awe in people's faces... i wouldnt bother tight autox parking courses since they're too tight for such a large car, but I'm interested to see what your car can do in a nice wide road curvy and see what cars you're running with
  10. #50 Re: Vogtlands vs Eibach
    Had means past tense.. see my sig for current car.
    Ask ScottyDoggs or JRotton about how the car handled, I said it was good... but ask a third or fourth party. They were the ones crying like little girls.
    Never took the car crossing. Pulled the motor at 204 when it hung a valve and dropped in a S3 NA. Sold the car in late April of this year with 260K on it. Plenty of people on here either drove it or rode in it. Struts/springs went on at 160 and were sold with it at 260, still felt good. JRotton took a ride right before I sold it, he can attest for how good/bad the combo felt at 100K
    As for the Potenza's.. they are amazing.
  11. #51 Re: Vogtlands vs Eibach
    Aug 2015
    Earth
    Lol I'll take your word for it and I didn't realize you were writing in past tense the entire time lol, I assume your car oversteered with lift off throttle? Hence the crying like little girls?
  12. #52 Re: Vogtlands vs Eibach
    Scotty will find the thread soon enough...
    I'm sending John a link
  13. #53 Re: Vogtlands vs Eibach
    Dec 2013
    Enfield
    That car was tight, you would never know it had that kind of mileage. In my limited time in the car, I was impressed and that is not easy. I have had lots of fast cars, more than most. I like cars that handle as I'm not a quarter mile guy. I drive a 2008 GP GXP now. And Bill's driving will scare anyone, he takes cars to the limit . I would believe him.
  14. #54 Re: Vogtlands vs Eibach
    Feb 2013
    Missouri
    Here's the Addco for Dezebe1, You should check out his thread, lost of useful info on various things including suspension.
    http://www.grandprixforums.net/threa...=1#post1373354
  15. #55 Re: Vogtlands vs Eibach
    That wasn't the limit.. had plenty left it in!
  16. #56 Re: Vogtlands vs Eibach
    Dec 2013
    Enfield
    There is a bigger Addco bar than that bar, if still available. Its 25mm . It should work, I don't own it so purchase at your own risk
    http://www.neverenoughauto.com/i-192...lizer-kit.html
  17. #57 Re: Vogtlands vs Eibach
    SE Level Member Acdc88's Avatar
    Jul 2015
    St Peters
    Definitely go with the (anti) sway bar upgrades that were mentioned above. I followed their advice and the handling improvement is fantastic.
    02 GT : BMR Trailing Arms, F&R Lateral Arms, F&R Strut Tower Braces. Progress F Anti-Sway Bar. Addco R Anti-Sway Bar. Moog Problem Solver Bushings & "CK" Control Arms. K&N CAI. HV3. MSD Coils and Wires. ZZP 1.0. ZZP Front P-Log. ZZP 2.5" Cat'd Downpipe. C5 front brakes, GXP rears. Full Borla Cat Back. BC Coils. Niche 18s
  18. #58 Re: Vogtlands vs Eibach
    Aug 2015
    Earth
    Edit: well that's definitely legit.....and its for 98-08 impala so it is for our cars.... hmm I've never read of anyone running 2179, everyone always fights over the 22 mm aco639... this is really weird
  19. #59 Re: Vogtlands vs Eibach
    Feb 2013
    Missouri
    It might just be the file picture, but that doesn't look like out rear sway bar at all. Different endlinks and all.
    Edit: I just saw the generic picture *. lol
  20. #60 Re: Vogtlands vs Eibach
    Now I see this..fudge
    04 Comp G.
  1. Questions for people with Vogtlands
    By wa04compg in forum Brakes/Suspension/Chassis
    Last Post: 10-29-2014, 01:32 PM
  2. SSC or Eibach?
    By SerenityGTO in forum Brakes/Suspension/Chassis
    Last Post: 05-19-2011, 06:34 AM
