Thread: Small question about fbody brakes
Results 1 to 7 of 7
  1. #1 Small question about fbody brakes
    Canada
    Hi guy's. My 08 Grand Prix need brakes . I'm looking in fbody brake from ZZPerformance. I have the stock 16'' wheels, and i want to know if i can put adhesive wheel weight in the inside of the wheels or the wheel are to small? I'm looking for that because i hate the look of the outside clip ...
    Thanks!
  2. #2 Re: Small question about fbody brakes
    Kemmerer, Wyoming
    don't buy the kit from zzp. you can put it together for half the price if you put it together yourself. you should be fine with the wheel weights inside the wheel.
  3. #3 Re: Small question about fbody brakes
    Canada
    But i will need the bolt kit from ZZP? ZZP sell the kit with bolt-on braket. The shipping is very bad for me with ZZP. 275$ to Montreal for only 2 calipers ...
  4. #4 Re: Small question about fbody brakes
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I was able to run stick on weights inside the wheel while I had my f body setup, now once I went to corvette C5 calipers...no
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  5. #5 Re: Small question about fbody brakes
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by Le Patriote View Post
    Thanks!
    You may also want to consider the 06-13 Impala stock brakes. They bolt on with minimal modification, dual piston, similar performance.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  6. #6 Re: Small question about fbody brakes
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    this ^
    the only difference is the fbody is aluminum so it makes them lighter. the fbody brackets won't bolt up directly because they use 12mm bolts instead of 14mm. the impala brackets bolt right on. plus the f body banjo bolts are different. save yourself money and headaches and just by the impala stuff. you'll need the brackets , calipers , brakes and rotors.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  7. #7 Re: Small question about fbody brakes
    If you source the calipers, bolts and brackets locally, then get 4 sleeves to fix the sizing of the bolts.. you'd have it all w/o a billion dollars of shipping.
    I did this in the US for $60 shipped on the calipers, brackets and bolts. Then picked up rotors and pads of my choice.
  1. WTB: FBODY brakes
    By stlmo_gtp in forum Wanted To Buy - Parts
    Last Post: 08-22-2014, 01:59 AM
  2. Fbody brakes and painting
    By Timing in forum Brakes/Suspension/Chassis
    Last Post: 06-19-2014, 11:43 PM
  3. fbody brakes
    By WIgp02 in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2013, 12:03 AM
  4. Need help with FBody brakes.
    By Sudden in forum Brakes/Suspension/Chassis
    Last Post: 08-14-2010, 03:16 PM
  5. Need help (Fbody Brakes)
    By 98GT3800 in forum Brakes/Suspension/Chassis
    Last Post: 01-14-2009, 05:38 PM
