Thread: Trailing arm question
Results 1 to 8 of 8
  1. #1 Trailing arm question
    Donating User
    Jul 2014
    Minnesota
    Years ago I bought a GMPP package that included the tubular trailing arms, I had serious trouble getting the old ones off so I didn’t do it. Recently I replaced the rear sway and decided to install these arms. It was a PITA to get the old ones off. I realize the factory ones are stamped steel and the new ones are tubular. I am wondering what the purpose of the trailing arm is and what is the improvement of the new tubular ones?
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: Trailing arm question
    Antioch, IL
    take the trailing arm off and kick your tire, your answer will follow
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Trailing arm question
    St. Louis
    The trailing arms keeps the rear tires straight with the body so the car tracks straight. The tubular arms reduce the flex that the factory ones likely have thus giving you a more stable ride especially during cornering/turning.
  4. #4 Re: Trailing arm question
    Donating User
    Jul 2014
    Minnesota
    Quote Originally Posted by ITHURTZ View Post
    Thanks but i dont wanna take the wheel off.
  5. #5 Re: Trailing arm question
    how can you not see wtf the trailing arms do, as well as the other two bars per side.
  6. #6 Re: Trailing arm question
    Quote Originally Posted by 00RedfireGT View Post
    wat?
    how're you doing this install without the wheels off? fo' reelz?
  7. #7 Re: Trailing arm question
    hangover park IL
    under hard braking while driving forward the knuckle pulls on the trailing arm to transfer the forces to the body.
    it is only ever under tension unless you like locking up the brakes while driving backwards at high speed while slamming on the brakes...then it'll be under compression and only then would the OEm "U" channel trailing arms tend to deflect/deform.
    the change in bushings to a firmer material is the only real upgrade over oem.
    meh they doo look good when you can see em with it's ass in the air rolling on front springs/cable mod
    ~James~ Psychotic Gearhead
  8. #8 Re: Trailing arm question
    Donating User
    Jul 2014
    Minnesota
    wat?
    I said that in response to the first answer I got. I have already installed them.
  1. So am I missing something? Trailing Arm question...
    By Booba5185 in forum Brakes/Suspension/Chassis
    Last Post: 04-02-2015, 10:15 AM
  2. Question about rear trailing arm bolt...
    By littlehoov in forum General Tech Discussion
    Last Post: 02-25-2014, 08:22 PM
  3. Trailing arm question
    By Daveliz99 in forum Brakes/Suspension/Chassis
    Last Post: 08-19-2013, 11:37 PM
  4. question about trailing arms
    By ad4m in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 09:51 PM
  5. Trailing Arm
    By nault31 in forum Oldsmobile Cutlass
    Last Post: 02-09-2010, 04:00 PM
