Thread: STB differences
Results 1 to 7 of 7
  1. #1 STB differences
    Donating User
    Jul 2014
    Minnesota
    I purchased the GMPP suspension kit and I am wondering what the difference is, if any, between the STB that comes with it and the tubular ones that are available.
    Thanks for your input.
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: STB differences
    Buffalo
    the STB or strut tower bar, is the stock bar that came on most of the GTPs and Regals. The only tubular ones I know of are aftermarket. They attach to 2 or 3 of the upper strut bolts vs the factory mounting location, which also requires the factory mounting kit sold separately
    I run the stock STB bar with aftermarket mounting plates
  3. #3 Re: STB differences
    SE Level Member Acdc88's Avatar
    Jul 2015
    St Peters
    I would assume that the tubular options are a bit more rigid. I doubt the difference would be that noticeablethough. Thicker sway bars and control arms are going to improve handling much more noticeably than the STBs. I have BMR front and rear and the improvement was minimal, but they are beautiful STBs.
    02 GT : BMR Trailing Arms, F&R Lateral Arms, F&R Strut Tower Braces. Progress F Anti-Sway Bar. Addco R Anti-Sway Bar. Moog Problem Solver Bushings & "CK" Control Arms. K&N CAI. HV3. MSD Coils and Wires. ZZP 1.0. ZZP Front P-Log. ZZP 2.5" Cat'd Downpipe. C5 front brakes, GXP rears. Full Borla Cat Back. BC Coils. Niche 18s
  4. #4 Re: STB differences
    Donating User
    Jul 2014
    Minnesota
    Thank you, that's what I was wondering.
  5. #5 Re: STB differences
    Buffalo
    i can't justify why an aftermarket bar would be better then the factory bar besides looks and additional cost
  6. #6 Re: STB differences
    Arizona
    The aftermarkets well, some of them like BMR have the ability to put tension against the strut towers which is really what you want the other ones that have little surface area and just on the inner portions of the strut tower are not nearly as effective.
  7. #7 Re: STB differences
    Buffalo
    Yeah. They have the threaded ends.
    Ive had both the factory mounts and these aluminum brackets.
    It it was the rear bar that apparently proved these work. The rear bar was installed before there was aluminum adapter plates made. You would slightly elongate the holes on the stock front bar and it would fit
    Fast forward a year or two , I get the plates made , removed the rear bar and I was shocked. The holes actually stretched a lot meaning there was some serious force going on back there.
    Id spend the money getting a rear bar before getting one pretty one
  1. Anyone tell me the differences
    By DarkPassNger in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-14-2014, 04:27 PM
  2. TB differences between 97 and 98-03 TBs
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2012, 07:21 AM
  3. L67/32 Alt Differences
    By footballplaya3k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2011, 03:06 PM
  4. l36/l26 differences
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2011, 09:20 AM
  5. GT/GTP MAF differences?
    By pontiackid in forum General Tech Discussion
    Last Post: 05-24-2009, 07:47 AM
