Thread: Changing driver side rear caliper in 05 gp gt
Results 1 to 3 of 3
  1. #1 Changing driver side rear caliper in 05 gp gt
    Aug 2015
    Virginia
    I cannot get the E-Brake line off of the caliper, ive gone underneath loosened the wire and still nothing... it is just starting to piss me off at this point, anyone that knows an easy way to do this would be greatly appreciated
  2. #2 Re: Changing driver side rear caliper in 05 gp gt
    Does it see like the cable is not moving in the sheath? If so.. cut it and buy a new cable, they are about $20-$30 each side.
    I believe you have to undo it nearly 100% to get enough slack to sneak it out of the caliper.
  3. #3 Re: Changing driver side rear caliper in 05 gp gt
    Nov 2014
    Macon, GA
    pry the e-brake lever back , it is probably froze.
    Also you have to loosen the cable in the middle a long way.
  1. Driver-Rear Caliper Piston not retracting
    By Exile in forum Brakes/Suspension/Chassis
    Last Post: 02-03-2014, 02:25 AM
  2. Has anyone had a problem with the driver side rear caliper locking up?
    By Doug 97 gtp in forum Brakes/Suspension/Chassis
    Last Post: 09-16-2012, 08:29 AM
  3. Loud clunk in driver side rear
    By MizzBecca in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2012, 05:44 AM
  4. Rear driver-side window
    By VejGTP in forum 04+ Specifics
    Last Post: 10-14-2011, 01:02 PM
