robinsone
If you get the front harnesses, there are 2 of them the shorter driver's side (DS) and the longer passenger side (PS). In theory you really don't need the much longer PS one, but to be safe I'd grab it. I soldered in the new harnesses about 8-10 inches from the DS main harness and about 12 inches from the PS main harness. I wouldn't go all the way back to the main harness. With the car jacked up on one side there is enough space to remove 75-80% of the old harness which I found to be enough and then easy enough to work with a soldering iron to make connections to the new harness.
You will easily be able to tell how inflexible the old harnesses are compared to the new ones. Just be sure to incorporate plenty of slack in the harness when attaching it to the control arm (CA) so any articulation in the CA won't pull at the new harness or connections.
Just do one side at a time, pop the tire off and splash shield it goes quick. You might want to have some extra shrink wrap. Some of the kits just came with clamps and I prefer soldering and shrink wrap and then plenty of electrical tape, and some wire ties to secure any slack near the main harness. Since doing this I haven't had one problem with it.
