thanks for the reply. I ended up going with a reman from detriot with lifetime warranty. Curious how did you mark your tie rods for re install and did you drain all of the fluid out completely or just want ran out with lines dropped. I am starting this later today so want to make sure i do everything that needs to be that is necessary. Also my steering wheel is already crooked so im hoping this will fix it in the process. Thanks for your help.
