Thread: Wheel sensor going bad again in new hub?
Results 1 to 6 of 6
  1. #1 Wheel sensor going bad again in new hub?
    Mar 2015
    USA
    When I got this car I chased all kinds of ABS issues and finally got it all fixed. (New LF hub, and new RF harness)
    One was a bad wheel speed sensor in the left front. About 1000 miles later I'm getting a C1225 LF wheel speed excessive variation.
    Sounds like my new hub is a piece of crap, or try the wiring harness first? FWIW, it acts up most at low speeds and when turning.
    I seem to recall every other time it was the harness, it caused a open or shorted sensor code.
  2. #2 Re: Wheel sensor going bad again in new hub?
    hangover park IL
    its likely a wire broken/intermittent inside the sheath.....it might eventually get bad enough to trigger an open circuit code.... id start there
    ~James~ Psychotic Gearhead
  3. #3 Re: Wheel sensor going bad again in new hub?
    SWPA
    if you put a junk generic hub in then it is possible it is the hub already.
  4. #4 Re: Wheel sensor going bad again in new hub?
    Banned
    Jan 2013
    maryland
    Probaly the wire... I installed a moog hub about 2 weeks ago and thought it was hub... Turns out it was a short in the wire.. You gotta trace it down..
  5. #5 Re: Wheel sensor going bad again in new hub?
    Mar 2015
    USA
    Turns out it was the wire. At least both sides are new now. I suspected the hub since it had crappy reviews, but it was the only thing available at the time.
  6. #6 Re: Wheel sensor going bad again in new hub?
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by 2004l67 View Post
    So you replaced both sides? Spliced wire?
  1. wheel speed sensor issues
    By jhintz in forum General Grand Prix Discussion
    Last Post: 05-19-2014, 05:26 PM
  2. Wheel Speed Sensor
    By blackthunder in forum General Tech Discussion
    Last Post: 02-26-2014, 12:05 AM
  3. Wheel speed sensor
    By GXPrunner06 in forum General Tech Discussion
    Last Post: 03-22-2013, 10:30 AM
  4. left rear wheel speed sensor
    By anarchy in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2012, 04:28 PM
  5. ABS Wheel Sensor Harness, HELP
    By foursixer in forum General Tech Discussion
    Last Post: 04-14-2012, 10:38 PM
