Thread: Preferred struts for 01 gtp?
Results 1 to 13 of 13
  1. #1 Preferred struts for 01 gtp?
    Feb 2015
    I recently bought an 01 gtp and it could use new struts all the way around. Just wondering if anyone has a preference to a certain brand or any bad experiences with another. This is my dd 50 miles a day so I'm looking for comfort and reliability nothing extreme. Thanks all!
  2. #2 Re: Preferred struts for 01 gtp?
    Jan 2014
    AR
    Sensa-Trac quick struts on front of my 99. Ride OK but one mount was noisy from day one. Still is a year later but no failure and ride / handling is as expected.
  3. #3 Re: Preferred struts for 01 gtp?
    Feb 2015
    I've been doing some research and for the money the sensa trac looked like a good choice. Michigan potholes are killing me. Has the mount quieted down at all in the year you've had them on?
  4. #4 Re: Preferred struts for 01 gtp?
    Jan 2014
    AR
    Theres been no change. For awhile I thought maybe I'd douse it with silicone spray and pray but before that happened I learned to tune it out lol
  5. #5 Re: Preferred struts for 01 gtp?
    Feb 2015
    Lol I would have probably done the same. I always think about what I could do but sometimes you just never get around to it.
  6. #6 Re: Preferred struts for 01 gtp?
    I ran KYB's, they worked just fine for me.
  7. #7 Re: Preferred struts for 01 gtp?
    Feb 2015
    Which model kyb?
  8. #8 Re: Preferred struts for 01 gtp?
    The GR2's, I bought the struts/mounts/lowerng springs and put them together myself.
  9. #9 Re: Preferred struts for 01 gtp?
    Feb 2015
    I'm assuming stock coils will also work? Lowering isn't an option for me in Michigan with the roads being full of craters the size of a vw bug.
  10. #10 Re: Preferred struts for 01 gtp?
    Yeah.
    If the ass end isnt sagging, then I'd go ahead and reuse the stock coil springs.
    Another thing to note, quick struts will make the car like a 4x4. It's known that they will raise the car 1in ABOVE the factory height, and thats looks like butthole.
  11. #11 Re: Preferred struts for 01 gtp?
    Feb 2015
    It's got the saggiest ass in all the land lol The fronts hit like leaf springs and the left rear is rattling. Any rear coils you'd suggest then? I definitely don't want the rear sitting higher than the front.
  12. #12 Re: Preferred struts for 01 gtp?
    New factory coils would be just fine for the rear. Some people put olds intrigue rear springs in the back if they run subs for their jigga boom music makers. They ride slightly higher in the back and have a different spring rate I think.
    I've don't see front springs with sag that much.
  13. #13 Re: Preferred struts for 01 gtp?
    Feb 2015
    Haha jigga boom. None of that here. I'll probably throw the kyb's all around and new coils in the back and call it good.
  1. struts equal to GM konis struts
    By Dee23 in forum Brakes/Suspension/Chassis
    Last Post: 05-17-2015, 02:47 AM
  2. Preferred way to accelerate w/o wheelspin
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 09-07-2009, 12:37 AM
  3. Preferred Oil
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2009, 02:54 AM
